speedo issue
Old 07-14-2012, 01:25 AM
MyNinja9420's Avatar
Default speedo issue
so i have a 89 ex500 and my speedo im pretty sure is off, possibly up to 15 mph, i dont see how this could be possible with a cord driven speedo, and im almost positive the tire is the proper size, if not it will be in the next few days when the new ones are put on. Also jus a quick side question whats yr mpgs like? I put 2.6 gal in and only got like 50 miles although it seems to be doin better now, first time its actually been rode in god knows how long
Old 07-14-2012, 01:29 PM
That cable is gear driven. So the tooth count on the gear corresponds to a ratio that dictates the readout when coupled to another gear or ring. The gear assembly needs maintained. Cleaning, lubed and inspected. It is not uncommon for that assembly to wear out due to pressure washing, grit and grime from yrs of use, or like you mentioned, from lack of use.
Since the ride has sat for so long, cleaning and adjusting the carbs would be a must do item. My 05 EX500 has had a high of 68 mpg, but after richening things up abit, I am in the 55 mpg area at the moment.
Old 07-14-2012, 03:37 PM
Ok thanks, well i deffinatly know i need new airfilters mine are shot, jus waitin on some funds, but ill take the carbs off and clean them, mayb there not synced snd thats my problem
Thanks the the info on the speedo when i put the new tires on ill have to clean it up, do the gears mesh a certain way or does it not matter?
Old 07-15-2012, 03:34 PM
Doesn't really matter, you will feel it mesh when you place it, just make sure that the cable attachment position is towards the rear of the axle.
eclipsehunter2001
10-26-2006 12:24 AM
kawizx7
12-12-2005 06:45 AM
KORNOLIO
12-05-2005 11:46 PM
Green_05_636
11-12-2005 06:47 AM
gotrice
08-08-2005 06:18 AM
Quick Reply: speedo issue
