Flush mount lights
Old Sep 6, 2006 | 09:20 AM
05blk500r's Avatar
Default Flush mount lights
OK so i have these flush mount lights, and i was going to put them in place of the front running rights... Does anyone know how hard it is to take off the front fascia so i can get to all the goodies?
Old Sep 6, 2006 | 05:27 PM
calamarichris's Avatar
Default RE: Flush mount lights
It's a piece of cake. Simply loosen and remove:
~The (2) 10mm bolts located in the fairing just below the headlight/above the front fender
~The (2) phillips screws located on the sides of the fuel tank (securing the fairing to the tank*
~Both rearview mirrors
(Then as you're lifting off the fairing assembly...)
~The plastic headlight connector
~The plastic turn-signal connector
Once you've got the fairing off, you should have no problem accessing the little steel backplates that hold the turn-signals in place.
*Be careful when reinstalling these phillips screws--the threads are fine and easily cross-threaded/stripped.
Good luck and let us know how it goes.
-CCinC
Old Sep 7, 2006 | 07:31 AM
05blk500r's Avatar
thanks man it seems easy enough.....illl do that this weekend ill get back to you guys probally monday on how it looks...
Old Feb 12, 2007 | 02:04 AM
shox rox ice's Avatar
Sorry for the old thread bump but, wondering if you ever got these on and how they're working out? I was thinking about putting some on and doing a fender elim... anyone else have either and can recommend the best kits or ways to do it?
jared
Ninja 250R
Aug 6, 2011 10:23 PM
pfft84
Ninja 250R
Mar 28, 2007 12:00 AM
eniraM .S.U
Aug 10, 2006 07:00 AM
Scams06_6R
Dec 29, 2005 08:25 PM
peerpressure23
May 19, 2005 05:32 AM
