Flush mount lights
OK so i have these flush mount lights, and i was going to put them in place of the front running rights... Does anyone know how hard it is to take off the front fascia so i can get to all the goodies?
RE: Flush mount lights
It's a piece of cake. Simply loosen and remove:
~The (2) 10mm bolts located in the fairing just below the headlight/above the front fender ~The (2) phillips screws located on the sides of the fuel tank (securing the fairing to the tank* ~Both rearview mirrors (Then as you're lifting off the fairing assembly...) ~The plastic headlight connector ~The plastic turn-signal connector Once you've got the fairing off, you should have no problem accessing the little steel backplates that hold the turn-signals in place. *Be careful when reinstalling these phillips screws--the threads are fine and easily cross-threaded/stripped. Good luck and let us know how it goes. -CCinC |
thanks man it seems easy enough.....illl do that this weekend ill get back to you guys probally monday on how it looks...
Sorry for the old thread bump but, wondering if you ever got these on and how they're working out? I was thinking about putting some on and doing a fender elim... anyone else have either and can recommend the best kits or ways to do it?
