coolant hole
Old Nov 17, 2007 | 07:22 AM
Blackhawk2k7's Avatar
Default coolant hole
my 05 has a couple of scratches on it from previous falls (not by me) and the guy i traded my truck for it told me that it has a scratch that goes so deep that water from where the radiator hose connects to the engine is seeping coolant, now, what should i do to fix it, now remember its on the right side just a couple of inchs below where the radiatior hose connects to the engine, right where a fall would hurt it...
Old Nov 17, 2007 | 10:44 AM
calamarichris's Avatar
Default RE: coolant hole
If it's only the hose that connects the coolant pump to the radiator, simply replace it.
If you suspect the pump housing might be damaged, they can be found on Ebay regularly for pretty cheap.
Good luck and let us know how it goes.
Peace!
-CCinC
Old Nov 17, 2007 | 01:54 PM
dragknee's Avatar
a scratch so deep coolant leaks out? i wouldnt call that a scratch, id call it a hole lol.
if the case has a hole in it, get a new one. but while you wait, you can probably use some JB weld, depending on the size of the hole. you can use RTV in place of the gasket when you reassemble if you so desire.
if its leaking out of the hose, tighten the clamps. if that doesnt work, get a new hose.
too bad woodcraft doesnt make side cases for this bike
Old Nov 19, 2007 | 02:58 AM
hmmm... i have a sort of concrete cement, so ill use that, i was just asking because i thoughtit might be some high temp apoxy i had to use... thanks
Old Nov 19, 2007 | 03:36 AM
dragknee's Avatar
concrete cement?
Old Nov 19, 2007 | 04:37 AM
ORIGINAL: dragknee
concrete cement?
hahaha, have not seen a concrete hose on a ride yet. Seems kind of a bizzare fix.
Old Nov 19, 2007 | 04:48 AM
oh no its not a hose, its the metal part of the engine that connects to the hose clamp, also i mean contact cement
407guy
Oct 10, 2023 01:42 AM
IDRIDR
Feb 13, 2018 11:43 AM
incabiker
Feb 10, 2016 12:35 AM
Derosian
Ninja 250R
Feb 6, 2008 09:20 PM
