storing bike for winter
Old Nov 19, 2006 | 11:09 PM
mnosbor's Avatar
Default RE: storing bike for winter
I realize that this is an older thread but I wanted to add a few things to storing the 250.
The 250 carbs dont do well with gas left in them stabilized or not its best to drain the float bowls this is very easy. The tanks also rust easily so filling it up with stabillized gas will keep it from rusting. You can fog the engine if you like I dont bother if its going to get ridden here and there during the winter, if you are a fair weather rider only, then fog the engine. When Im done riding I top off the tank with stabilized gas and drain the float bowls takes about 10 min tops.
I also make sure the antifreeze is still good and put the battery on a tender.
Old Nov 20, 2006 | 08:22 PM
Mott Power's Avatar
I'm also storing my bike for the winter and had a quick question. I plan on doing a fuel stabilizer and new oil and take her for a ride to get everything circulating in the galleries and the stabilizer in the carb's. But what kind of oil should I use? Last owner recommended 5W-40. BTW, bike has 38,000 miles........ yeah, I know...
Old Nov 23, 2006 | 06:47 AM
viper186's Avatar
ORIGINAL: kawasakifan700
I too might be getting a 250 soon and will need to store it winter time also. Is it alright to start it every now and then just for a couple minutes and then park it again or would it be better to just leave it all winter. The reason I ask is because I heard that if you dont physically ride it oil is not gettin anywhere. Any feed back will help thanks.
Yeah Caddydaddy pretty much covered it. I thought Id add my 2 cents anyways. I was talkin to a mechanic and I thought that you should start it every now and then for a few minutes just to keep things moving but he said that if your going to start it you should always ride it for at least a couple of miles before putting it back away.
Old Nov 23, 2006 | 07:18 AM
true. but a 2 wheel slide in the summer is abit exaggerated in the winter.
Because of the tranny and load? question
Old Nov 23, 2006 | 07:42 AM
People store their bikes? Oh you have the wrong bikes, you need one of these then you can ride all year.
Old Nov 23, 2006 | 07:51 AM
show off!
Old Nov 23, 2006 | 09:19 AM
markmeinteil's Avatar
1+ lol
Old Nov 27, 2006 | 05:10 AM
CaddyDaddy's Avatar
ORIGINAL: deej
So you can ride that through two feet of snow, and do it safely??? Hmmm.....does anyone make snow tires for Ninjas?
Old Nov 28, 2006 | 05:34 AM
mnosbor's Avatar
ORIGINAL: Mott Power
The Ninja uses any 5w40 motor oil. DO NOT use any energy conserving oil, it will be marked in a circle on the label if it is. You can also use synthetic I havent switched mine over, its better if you have some miles on it first (btw you have plenty) I havent yet so I cant voice a personal opinion yet. I am looking at a second 250 this weekend with over 16k on it if the clutch feels good after having a go with regular oil I may throw some synthetic in it I havent decided yet.
Just make sure you drain the carbs when you are done running things through. It is very easy and will save you the hassle of going through them in the spring.
BeenJammin
Ninja 250R
Apr 25, 2014 02:25 AM
Brieninsac
Nov 13, 2012 11:02 PM
kyo babic
Ninja 250R
Sep 23, 2007 05:43 AM
raychizel
Nov 28, 2005 07:57 PM
