Sparkplug Boot Question
Old Sep 27, 2007 | 12:56 AM
kawasakifan700's Avatar
Default Sparkplug Boot Question
After a long night of wrenching I got to the sparkplugs to read em. I pulled em out... found them to be a little black so I decided I would get new ones tomorrow. I screwed them back in and I did the left boot first and it went on fine but then I got to the right boot and for some reason it wont go on all the way down. The rubber cap is about a quarter inch from touching the valve cover. Im not sure if I can just leave it like that or why its doing that?
Also im not sure but I think its the coolant reservoir behind the left side panel. Its in the low mark so I was wondering do I need to completely drain it or should i just add coolant?
Old Sep 27, 2007 | 01:21 AM
Default RE: Sparkplug Boot Question
Was it that way when you pulled the plugs?
Also im not sure but I think its the coolant resoivoir behind the left side panel. Its in the low mark so I was wondering do I need to completely drain it or should i just add coolant?
Used bike I would just flush the system then refill.
Old Sep 27, 2007 | 11:02 AM
ORIGINAL: Dragone#19
No Im pretty sure both of the rubber "gaskets' were touching the valve cover.
Ok thanks
Old Sep 27, 2007 | 11:54 PM
A lot of times the plug wire will move down in the boot on removal. Just slide the boot down more.
Not sure on this statement though.
Old Sep 28, 2007 | 12:16 AM
Thats exactly what happened. I was gonna shoot myself for something so easy that I spent hours trying to fix last night
Oh and I said gasket cause I wasnt sure what it was called [&:]
Old Sep 28, 2007 | 12:38 AM
hahaha, no worries. You sound like you are good to go then.
frankb
Mar 12, 2010 02:56 AM
sunspec
Ninja 250R
Aug 15, 2008 09:31 PM
KFalc
May 31, 2006 05:12 AM
jds636
Feb 1, 2006 04:43 PM
kawizx7
Dec 14, 2005 04:52 AM
