Rough start
Old Nov 29, 2007 | 07:07 PM
Phil2801's Avatar
Default Rough start
Ok Im about to winterize the bike and b4 I started I wanted to start her up for a sec and let the gas run out of the line , and when I did this It sounded like the motor was working REALLY hard like it wasnt a knocking sound but a really rough engine noise . Mind you it is about 45-50 degrees in my garage so im guessing that might have been the problem, Either way I immediatly turned the bike off after a few seconds of hearing the motor. Any ideas would be a big help .
Old Nov 30, 2007 | 04:09 AM
Default RE: Rough start
How long was she sitting after the last ride? What wt of oil?
Old Nov 30, 2007 | 08:18 PM
Phil2801's Avatar
Well it was sitting for about 8-10 days or so , and Im running 10-w30 in it atm .
Old Dec 1, 2007 | 03:29 AM
That time frame is not bad. what was the idle speed when these noises were happening at? Low idle rpms? Moisture in the gas? Right now, am thinking of just what you mentioned. Just too cold, a cold start which sounds abit rough on initial start up. the choke work to increase the idle until temp is reached before you shut the fuel off?
KINGVEGAS
Ninja 500R
Apr 25, 2007 07:03 PM
kawiridr04
Feb 27, 2007 06:03 AM
GS247
Jan 29, 2007 03:44 PM
norsseman
750
Jun 23, 2006 09:19 PM
