Oil warning light but no ignition or cranking
Old 01-30-2017, 06:07 AM
Knight-Rider's Avatar
Default Oil warning light but no ignition or cranking
Hi Guys,
I bought a non running GPX250 today(1995 model).
When I turn the ignition on the oil warning light come on, but no ignition lights.
Engine can't be cranked.
Oil level initially showed very low, then magically shows above full(sight glass is completely covered with oil).
Oil level was low when on side stand, and then "overfilled" when on center stand.(I just moved the bike on neutral during that time around the garage).
Indicator lights are working. Rear brake/park lights are working, and engine oil warning light comes on & that's about it.
Kill switch is on the right position.
Any ideas, help, thoughts, tips advice please.
I would at least like to crank the motor to see if it turns.
Photos attached below.
https://goo.gl/photos/3bwv4s6epP92Xhua7
https://goo.gl/photos/So6a8FLMFq1XhfRf6
Thanx.
Old 01-30-2017, 04:46 PM
I'm pretty sure that oil warning light is an indicator for low oil pressure, not low oil level. Don't have the oil over-filled when trying to start.
Before running off to start the bike with the starter, I'd first want to try turning the motor over manually by hand with a wrench to the crank shaft.
Try pulling in the clutch lever and make sure it's in neutral, then hit the starter button. Check fuses.
Old 01-31-2017, 02:04 AM
Thank you for the reply.
I managed to get it cranking.
It's an earth wire that's been disconnected, probably purposely to stop anybody cranking it. I cranked it for few seconds, but I had oil drained already, so the low oil pressure showing now is obvious. I'm just about to fill up with new oil and see it again.
I think you're right, the engine's probably worn out to the point oil pressure is too low.
But, I'm still wondering how is it able to detect that without cranking the engine??!!! I know in cars, low oil pressure is on when the ignition is turned on and goes away when we start the engine or stays on if the oil pressure is low. Can it be some other issue with the lubrication system for the oil warning light to come on?
Thank you in advance for your help, advice.
Old 01-31-2017, 07:21 AM
I managed to get it started.
The carb's flooding, so can't keep the petrol flow going into the carb, but it runs and idles
fine when I give a bit of petrol and cut the flow.
Float issue, I think?
Just trying to do a compression test safely without blowing the CDI.
Not sure, how to do it safely, so I'm googling and trying to find it in the manual.
Old 01-31-2017, 12:06 PM
Did the compression test and both cylinder came out as 150psi.
I'm wondering if it's ok!!!
Engine's running now and idling ok(carb floods though).
No black smoke.
Old 01-31-2017, 02:35 PM
Congratulations. With that old of bike, likely do have carb float issues.
Old 02-01-2017, 11:47 AM
Thanx. Yeah, it sure has carb issues, 'cos it's been left aside for too long and the tank has lot of internal rust, which surely got sucked into the carb and might have done some clogging of the carb "arteries".
Old 12-15-2019, 02:40 AM
durielk's Avatar
So, the only real thing u did was put new brushes in?
Do you use your start a lot and what's your mileage?
dboxman7
ZZR 600
09-19-2008 02:10 PM
Buddy Lee
04-01-2008 06:47 PM
Diallo
11-05-2006 09:17 PM
gek56
04-19-2006 03:09 AM
Jutboy
04-12-2006 06:23 AM
Quick Reply: Oil warning light but no ignition or cranking
