Engine oil light
Old Nov 5, 2006 | 04:58 AM
Diallo's Avatar
Default Engine oil light
Hi, I just did an oil change on my 06 636. I was wondering if you could help me. For those of you with an 06 636 , does your engine oil light come on when you have the key turned to on? Mine does and stays on untill I start up the motorcycle then it goes off. I put the correct amount of oil in and have checked the reading on the oil tank to see the engine oil level and its between the lines. Im just being safe...
Old Nov 5, 2006 | 05:08 AM
GS247's Avatar
Default RE: Engine oil light
Yes it should stay on until you start your bike. It is an oil pressure light. It comes on when you have no oil pressure. When your key is on, engine off, you have no oil pressure due to the fact that your bike is not running. As soon as you start your bike your oil pump builds pressure and the light goes off.
Another words everything is normal.
Old Nov 5, 2006 | 05:24 AM
Diallo's Avatar
Thanks!
Old Nov 5, 2006 | 08:47 AM
GS247's Avatar
no prob man!
Old Nov 5, 2006 | 09:17 PM
lemac's Avatar
Well that was easy... Btw welcome to the forums.
Israel-klx250s
Mar 4, 2012 08:33 AM
09klx
May 12, 2010 08:43 AM
slablocal
Jul 8, 2006 08:21 AM
kawi636
Apr 4, 2006 09:26 PM
