Baffles cut out need HELP
Old Sep 5, 2007 | 06:50 PM
89KLF220's Avatar
Default Baffles cut out need HELP
Hey guys I'm looking to cutmy baffles out of my 05 250R and from what i here its not that hard, but after i cut them out will thebike run lean? Plz help cause I'm tired of the stock exhaust lol!!!
P.S. if avalible but not needed does anyone have a step by step for me?
Old Sep 5, 2007 | 06:54 PM
jazzman's Avatar
Default RE: Baffles cut out need HELP
I don't know about removing them but if you drill out the rivets on the end and then drill 4 more holes between those holes, the exhaust sounds a lot better. i know a couple of 250's that have done that with no adverse performance effects.
Old Sep 5, 2007 | 07:15 PM
89KLF220's Avatar
but if I drill out the rivets wont the little plate come off?
Old Sep 5, 2007 | 08:29 PM
mnosbor's Avatar
Anything you do to change the amount of intake or exhaust air will affect carb jetting. So you are likely to run lean from it. Personally I find the sound of hacked mufflers on small bore engines grating on the nerves. You never know when someone will try to jack with you just because your exhaust is irritating.
[align=left] [/align]
Old Sep 6, 2007 | 12:17 AM
ORIGINAL: mnosbor
[align=left][/align]
hmm, +1. You alter one thing, it affects the whole package. Even show room rides need altered from the get go because of factory tolerances.
jacksonriding7
Jul 31, 2015 02:17 AM
Robert Del Valle
Jan 4, 2012 02:36 AM
zzrotceh
ZZR 600
Feb 1, 2011 06:23 PM
jake8
800, 800 Classic & 800 Drifter
Mar 26, 2007 12:41 AM
candy250r
Ninja 250R
Aug 10, 2006 11:03 PM
