Baffles cut out need HELP
Hey guys I'm looking to cutmy baffles out of my 05 250R and from what i here its not that hard, but after i cut them out will thebike run lean? Plz help cause I'm tired of the stock exhaust lol!!!
P.S. if avalible but not needed does anyone have a step by step for me?
I don't know about removing them but if you drill out the rivets on the end and then drill 4 more holes between those holes, the exhaust sounds a lot better. i know a couple of 250's that have done that with no adverse performance effects.
Anything you do to change the amount of intake or exhaust air will affect carb jetting. So you are likely to run lean from it. Personally I find the sound of hacked mufflers on small bore engines grating on the nerves. You never know when someone will try to jack with you just because your exhaust is irritating.
[align=left] [/align]
ORIGINAL: mnosbor
[align=left][/align]
