Grip Glue
Old Dec 24, 2006 | 10:03 PM
tamadrmr26's Avatar
Default Grip Glue
Has anybody ever heard of using hair spray instead of grip glue? Some how my local shop has been out of grip glue for a week andsomeone there told me hairspray would work.
Old Dec 25, 2006 | 02:05 AM
Notstock's Avatar
Default RE: Grip Glue
Aqua net! It will work fine.
Old Dec 25, 2006 | 03:14 AM
hahaha, reminds me of the '70's now. hairspray lubes the grips for a short time before it bonds.
Old Jan 28, 2007 | 07:13 AM
EvildoerZX10R's Avatar
Hairspray does work as long as it doesn't get wet. It is water salable (or however you spell it)so, when you get a tarein your grip or if you get water in from washing it could loosen it right up. Just use the glue, it's made for it.
Old Jan 28, 2007 | 03:06 PM
https://www.kawasakiforums.com/m_104783/tm.htm
check that thread out.... lots of good ideas... and if hairspray is water soluable.... not good on a dirt bike, i go through water alot.....
Old Jan 29, 2007 | 12:36 AM
KevyzToy's Avatar
I've always used hairspray. Spray some on the inside of the grip, slide the grip on, twist it some to spread hairspray all over handllebar, and let it set overnight.
Old Feb 3, 2007 | 02:26 AM
dieselmech's Avatar
The best stuff I have used to date (and I've tried lots of stuff) is superglue! dump a whole tube in each grip give it about 15 minutes (if that) and they will not move.
Old Feb 3, 2007 | 02:56 AM
"superglue! dump a whole tube in each grip give it about 15 minutes (if that) and they will not move."
hahahaha, Just hope you do not replace grips often.
Old Mar 13, 2007 | 05:25 AM
KX250F00's Avatar
Iknow not alot of people are strong believers in this but gasoline works great, dont use to much, i will eat through your grip, just swish a little in the grip, slip it on, and let it set in the sun, the gas evaporates, and the grip is pretty much vaccum sealed onto the bars, never slipped on me
davidgrip
May 20, 2012 11:25 PM
Worlok14
May 26, 2011 08:51 PM
09klx
Jun 28, 2010 10:07 PM
Notstock
Aug 29, 2007 01:18 AM
flash105
Oct 16, 2006 10:16 PM
