EVC Gasket New one fits or just glue old?
Old May 20, 2012 | 04:37 PM
davidgrip's Avatar
Default EVC Gasket New one fits or just glue old?
My 09 has the EVC Gasket oil leak , and after removing the gasket does not fit. Does the new gasket fit or do you need to glue it in place. I know you silicone seal the lobes, but do you need to glue the gasket to hold it in place. I noticed there was a brownish glue on the gasket in various spots, from the factory build. Thanks.
David
Old May 20, 2012 | 06:12 PM
Apparently this isn't uncommon on some of the '09's. It's like the rubber shrinks or such. You'll probably need a new gasket, and it will retain its shape and size. And correct...only necessary to seal the cam lobe indentations.
Old May 20, 2012 | 06:59 PM
redpillar's Avatar
Yes you can, with patience get the old gasket to go back on but you are better off to buy a new OEM gasket, and replace it. The 09 factory one seems to be made of some inferior material, or someone fell into the vat when they were mixing up the rubber….
Old May 20, 2012 | 08:07 PM
davidgrip's Avatar
Buying New. Thanks for your help.
David
Old May 20, 2012 | 11:25 PM
punkenduro09's Avatar
from what i know, the oe gasket is too small, buy a new oem gasket and youll be fine. also, use a bit of gasket sealer on the corners of the half moons, it will help keep it from leaking
JHNguyen89
Jun 9, 2011 09:56 PM
Worlok14
May 26, 2011 08:51 PM
09klx
Jun 28, 2010 10:07 PM
tamadrmr26
KX250 & KX250F
Mar 13, 2007 05:25 AM
flash105
Oct 16, 2006 10:16 PM
