What glue to put on boot for top of carb?
Old Jun 27, 2010 | 09:15 PM
09klx's Avatar
Default What glue to put on boot for top of carb?
As the title says What glue did u guys use on the boot where the needle is in the carb?
Old Jun 27, 2010 | 11:50 PM
Brewster's Avatar
None. When the diaphram rubber is compressed, it seals it.
Ride on
Brewster
Old Jun 28, 2010 | 12:18 AM
FM_Thumper's Avatar
Are you talking about the boot or the diaphragm?
Old Jun 28, 2010 | 12:55 AM
09klx's Avatar
The boot to the top circular metal piece. Has 4 screws.
Old Jun 28, 2010 | 01:12 AM
FM_Thumper's Avatar
That's the diaphragm. Yeah it should just fit in the grooves unless it expanded. It supposedly expands if you don't put it in hot water immediately upon removal. I always do that so I don't know if it really do expand or not.
Old Jun 28, 2010 | 08:29 AM
slippery750's Avatar
Glue?
Old Jun 28, 2010 | 08:00 PM
drw's Avatar
drw
I did not soak my diaphragm in hot water upon removal while drilling the slide.
I did not use glue for reassembly.
No issues on either front.
Good luck with yours.
Old Jun 28, 2010 | 10:07 PM
jacksonriding7's Avatar
From: In North Western Jersey, but from Jackson, WY Originally
Should not be putting glue here at all. If diaphram doesn't seal it properly, need a new one is all. I did not put my diaphram in hot water... I had to fuss with it a bit to get it seated correctly, but wasn't unbearable. As long as it seats, unless you note a specific leak (like can see where dirt has found passage across where it should seal, I would not worry about it not sealing right as long as it's seated right.
davidgrip
May 20, 2012 11:25 PM
Worlok14
May 26, 2011 08:51 PM
davehayward1
May 2, 2007 09:06 AM
tamadrmr26
KX250 & KX250F
Mar 13, 2007 05:25 AM
flash105
Oct 16, 2006 10:16 PM
