Wiring a USB
Old May 10, 2020 | 06:37 AM
AussieCheech's Avatar
Default Wiring a USB
Tried searching but the search engine excluded USB when searching for 'wiring a USB.
I want to have it wired so that it only works when the ignition is on so that I don't accidentally drain the battery. Have any of you done this, and where/how did you connect the pos/neg to?
Thanks,
Cheech
Old May 10, 2020 | 08:48 AM
philgoodklx's Avatar
I got one from ebay (double USB and larger socket) with on/off switch. Wired direct to battery.
Old May 11, 2020 | 04:24 AM
Got mine from ebay as well, but without a switch. Surely someone has wired one to only work when the ignition is on?
Old May 11, 2020 | 05:36 AM
Found on another site that as it is only drawing 5 volts, people just tap into the rear taillight. That would work fine as I am running led taillight that draws nothing.
Old May 12, 2020 | 01:54 PM
azdeuce's Avatar
If you have a battery tender plug on your bike.. they make a USB adapter and a volt meter plug-in
I know you want a switch... just my .02 but they work great.. I have both
Old May 12, 2020 | 03:24 PM
gorgeguy's Avatar
I just saw this today. Looks like it has the switch you wanted:
https://techvibesoutlet.com/products...yABEgLzQ_D_BwE
Old May 12, 2020 | 10:55 PM
I did end up wiring it into the rear tail light. The wiring for the light happens to run through just behind the airbox, so I was able to splice in to the red tail light wire there. And ran the negative straight to the battery. works well.
Old May 13, 2020 | 06:11 PM
Brieninsac's Avatar
Here are two threads I created on the topic quite some time ago. Unfortunately, the pictures are no longer hosted but you'll get the gist by reading the threads.
https://www.kawasakiforums.com/forum...install-38003/
https://www.kawasakiforums.com/forum...-switch-38354/
Old May 13, 2020 | 08:22 PM
ekim250's Avatar
This seems like a good option if you already have a tender wired in.
Amazon Amazon
Old Jun 10, 2024 | 10:07 PM
raketemensch's Avatar
Where in here were you able to tap into a red wire?
luke.strain
Ninja 500R
Mar 23, 2019 07:31 PM
nicko
Classic Touring Bikes
Jun 26, 2015 09:27 AM
Kobuk
Apr 7, 2014 02:50 AM
Ratdink
Apr 14, 2007 04:12 AM
miunik7r
Ninja ZX-7R
Oct 3, 2006 02:22 AM
