Wiring a USB
Tried searching but the search engine excluded USB when searching for 'wiring a USB.
I want to have it wired so that it only works when the ignition is on so that I don't accidentally drain the battery. Have any of you done this, and where/how did you connect the pos/neg to? Thanks, Cheech |
I got one from ebay (double USB and larger socket) with on/off switch. Wired direct to battery.
Got mine from ebay as well, but without a switch. Surely someone has wired one to only work when the ignition is on?
Found on another site that as it is only drawing 5 volts, people just tap into the rear taillight. That would work fine as I am running led taillight that draws nothing.
If you have a battery tender plug on your bike.. they make a USB adapter and a volt meter plug-in
I know you want a switch... just my .02 but they work great.. I have both |
I just saw this today. Looks like it has the switch you wanted:
https://techvibesoutlet.com/products...yABEgLzQ_D_BwE |
I did end up wiring it into the rear tail light. The wiring for the light happens to run through just behind the airbox, so I was able to splice in to the red tail light wire there. And ran the negative straight to the battery. works well.
Here are two threads I created on the topic quite some time ago. Unfortunately, the pictures are no longer hosted but you'll get the gist by reading the threads.
https://www.kawasakiforums.com/forum...install-38003/ https://www.kawasakiforums.com/forum...-switch-38354/ |
This seems like a good option if you already have a tender wired in.
