wich type of silicone to seal the stator wire ?
Old May 15, 2018 | 08:36 PM
Hockey4ever's Avatar
Default wich type of silicone to seal the stator wire ?
I had to remove the stator cover on my KLX 2013. My welder fixed it after i craked it in a crash!!!! . So now, i see in the service manual, that they are mentioning to put silicone around the stator wire that goes ttrough the stator cover. Wich type of silicone should i put? Construction silicone? gasket silicone? Thanks
Old May 15, 2018 | 09:41 PM
RaceGass's Avatar
Rtv type works fine. Available at any auto zone or kragen auto parts
Old May 16, 2018 | 01:27 AM
GBAUTO's Avatar
If you have access to Permatex gasket products, I'd suggest either UltraBlack or UltraGrey. Clean the grommet/wires with some spray brake cleaner and then apply a dab on the harness and install. Let the RTV dry/cure overnight and no leaks.
Old May 16, 2018 | 01:36 PM
I have access to ultragrey or ultrablack. Wich one is the best for this application? Ultrablack seem for high temp. Is the alternator cover considered high temp?
Old May 16, 2018 | 03:06 PM
GBAUTO's Avatar
Doesn't matter-either will work perfectly. At this point, it's just window dressing as far as color.
Old May 16, 2018 | 05:05 PM
Cool!! Thanks :-)
Old May 18, 2018 | 10:52 PM
reinigef's Avatar
Nice, I'm glad you got it fixed. I'm Curious and would like to know what kind of weld (Tig, Mig) was used and the rod/wire that worked. This is good info!
Addendum- You all are AWESOME! I learn so much good stuff on here, THANKS!
Old May 19, 2018 | 02:40 AM
RaceGass's Avatar
Special mig silicone to keep the splatter down. The tig silicone just flows... wait a minute there’s no welding going on in this thread! Wtf!
Old May 21, 2018 | 05:11 PM
reinigef's Avatar
His aluminum stator cover cracked and he had it welded smart *** Race Gass. Cast aluminum, very tricky.
Old May 22, 2018 | 06:45 PM
RaceGass's Avatar
I’ve cracked magneto covers before. There’s a two part product for aluminum that even sets/hardens when oil is present. I think it’s called aluminaseal. I’ve never tried to weld cast aluminum, I know it’s tricky requiring a lot of preheating. Sorry for the smart *** comment since the op asked about silicone sealer. A local fabricator by the name of Rob North (google his name he’s a English road racer that can fabricate some very cool stuff) who warned me welding a cast aluminum cyl head coolant spigot in place, the cast aluminum can seem to evaporate if your not careful.
c.salt
Apr 3, 2018 04:20 PM
jfman
Feb 7, 2013 03:19 AM
JoelThailand
Oct 15, 2012 03:20 PM
TheDoc46
Mar 20, 2011 02:56 AM
Sideways1
Apr 18, 2010 04:13 PM
