Why is ny red oil warning light coming on? Is it a temp warning light?
Old May 2, 2018 | 12:07 AM
Brody Terry's Avatar
Default Why is ny red oil warning light coming on? Is it a temp warning light?
What red light is that and how can i fix it?
Old May 2, 2018 | 12:12 AM
RageHardIntoTheBendies's Avatar
Old May 2, 2018 | 02:21 AM
Werloc's Avatar
That’s the water/coolant temp. The bike will shut off if it gets to high for safety. These bikes are over cooled, and normally run on the cooler side. Check your coolant level, make sure the pump is moving the coolant. If that checks out ok, then check your jetting/mixture, as it may be on the lean side. The bikes are on the lean side from the factory for emissions.
Old May 2, 2018 | 12:57 PM
peabrain's Avatar
and check your thermostat.
TyCobb2000
Mar 28, 2017 03:00 AM
phambykansas
Dec 7, 2016 03:04 AM
mcwee68
Oct 12, 2015 10:55 PM
PalmStateCrawler
Jan 8, 2013 04:57 PM
NicePaint
Joke section!
13
Nov 26, 2007 03:50 PM
