Wheel interchange
Old Nov 6, 2018 | 02:25 AM
Geohaydook's Avatar
Default Wheel interchange
Will rims from a 2007 KLX 250 fit a 2010?
Old Nov 6, 2018 | 12:50 PM
Verwah's Avatar
Start here and if you don't find your answer browse the 'related topics' tab at the bottom of the page.
Old Nov 6, 2018 | 03:09 PM
If you mean wheels: Rear yes, with a change of rotor, has a 220mm rotor, the newer ones are 240mm I believe. Front, no has a different speedo drive that is not compatible. Only 2009 and up are direct bolt in replacement.
If you mean literally only the rims, yes, both use similar hub hole patterns and same number of spokes.
outrecording
Dec 24, 2015 10:00 AM
T_i_G_e_R
Jul 3, 2011 04:14 PM
duder
Jun 7, 2011 12:36 AM
work
Feb 6, 2011 02:06 PM
slimenlyman
Jan 19, 2008 04:09 AM
