What's your gearing combination and chain length?
Old Nov 21, 2014 | 02:59 AM
Originally Posted by IDRIDR
Thanks, Thad.
So, can I assume that although not ideal for chain karma, a 13/50 would also work with the 110-link but a 15/50 is questionable and may need 112-link?
Good article.
Yeah, plenty of adjustment in the snails for a 13T, and based on where mine are for a 14T, I wouldn't dismiss the likelihood of a 15T.
Old Dec 13, 2014 | 06:27 AM
Rock Hugger's Avatar
Has anyone ran a 13/49-15/49 with a 112 chain?
Old Dec 13, 2014 | 01:29 PM
MattyTracks's Avatar
13/42 with stock chain, stock chain rusts pretty easy(yes I oil it but I ride everyday in the rain) so I'm upgrading to a rk rx gold chain and 47 rear. Seems this combo you can run a 108 or 110, thinking I'll go with the 110 to allow larger CS in the future for touring.
Old Dec 13, 2014 | 04:36 PM
Check the very first post. I'm editing it to compile all the replies.
I've ran the gearing combo, but with a 110-link chain.
Old Dec 13, 2014 | 05:48 PM
Lutz's Avatar
Other than stock 14/42...
I've run 13/47, 14/47, and 15/47 with one chain and plenty of adjustment - I'll have to check length.
Old Dec 14, 2014 | 03:51 PM
KawaBiker's Avatar
Here is a table showing ratios. PM me if you want this in Excel to play around with.
For nearly stock (snorkel removed), 95% dirt / 5 % highway, trail riding I like 13/51.
It is not too low for my riding. On wide open two-lane in southern AZ I have hit 55 mph according to GPS. It will cruise at 50 mph, level ground, pretty well when I need to get between trails. Otherwise I trailer everywhere.
I am pretty sure the chain is 108 links (12/15: no, it is 110). I bought a 120, tried it on the new sprockets, and cut it down to the right length. Had to move the stock chain guide forward. Had to get a "master link press tool" to close the o-ring master link.
On page 272 of the latest https://www.rockymountainatvmc.com catalog there is a chain sizing guideline of "Add one or two teeth to front or rear sprocket, add two links to the stock chain length" and vice versa.
Last edited by KawaBiker; Dec 15, 2014 at 11:05 PM. Reason: Correct chain length, stock chain guide
Old Dec 14, 2014 | 05:46 PM
I am pretty sure the chain is 108 links.
I'd be interested to hear back on the number of links. There is no way I could get a 108-link to fit and I'm running 13/51 now (with a 110-link).
Old Dec 14, 2014 | 09:44 PM
How far forward is your axle in the adjuster with the 13/51? I have a 4.00x18 mt43 rear tire, the diameter is larger than stock and almost rubs the splash guard w/ 13/42 gearing.
Old Dec 15, 2014 | 10:20 AM
daren1093251's Avatar
I currently use 13/47, 108 and i've been using it for about 3,000 KM and i'm going to change again soon, not sure to what. I don't like how slow the bike is without hitting up like 9000 RPM to get to 85 km/h, but for trail riding, I coudn'lt ask for better she always she wants to jump up in the air and go
Old Dec 15, 2014 | 12:50 PM
4vman1's Avatar
I must be missing something. I've only had my 09 klx250s for about a month now, but right away I thought the previous owner geared it down since I felt 1st was almost useless and a shift to 2nd was immediately needed the second the clutch was out in first. I took off in second a few times my first real dirt ride. Upon closer inspection, 14-42 stock. I hated it on the little bit of road I have to do to hit trails. Yesterday I tried a 15 up front. At 65mph, it dropped the rpm's 1000 and on the trail, first felt a hair too tall, but at least it was usable instead of always needing second. But then I read on here people are dropping one on the front and adding 8 on the back. I feel like you'd be able to take off in third. I guess to each their own... I have a dj jet kit and klx mffler.
