Whats the difference-spokes and rims for a...
Old Feb 26, 2008 | 06:34 PM
Davebert's Avatar
Default Whats the difference-spokes and rims for a...
KDX220r front wheel and a KLX250s front wheel? They have different part numbers for the rim so is it larger/thicker spokes and holes in rim for the KDX220 wheel? They appear to be interchangeable as a whole unit with hub-spokes-rim and speedo drive?
Thanks,
db
Old Feb 26, 2008 | 07:33 PM
KLXer's Avatar
Default RE: Whats the difference-spokes and rims for a...
KDX front 95+ is what you want. Same brake rotor mounting (but a different rotor), same axle, same odo drive. The rims are also the same size. . If they have different part numbers they are cleary different parts but I am here to tell you they are interchangable & work.
Old Feb 26, 2008 | 07:34 PM
KLXer's Avatar
& by that I meant installing the complete KDX wheel to the KLX. I vener tried mixing & matching rim/spoke/hub combos. The brake rotor, odo drive, & axle are all interchangable though like I said.
Old Feb 26, 2008 | 07:43 PM
Davebert's Avatar
Ok, good to know as I got me a used one as I read they would work on the KLX once a long time ago on this forum I think. This one has a bent rim so I may have to buy a rim. So I just need to buy one for the KDX (as opposed to the KLX) so as not to mix spokes and hole sizes etc...Can I use the brake rotor from the KDX on the KDX wheel on the KLX or do I need to swap the disc??
Thanks,
db
Old Feb 26, 2008 | 07:47 PM
Davebert's Avatar
ORIGINAL: KLXer
I guess you already answered the rotor question
Thanks,
db
Old Feb 26, 2008 | 09:04 PM
KLXer's Avatar
Yep, can use either rotor. The KDX rotor is about half the weight BTW.
Old Feb 27, 2008 | 12:48 PM
Truckman's Avatar
rear wheel??? same one will fit???
Old Feb 27, 2008 | 06:07 PM
KLXer's Avatar
95+ KDX rear fits too.
Doc Gatling
Jul 18, 2017 05:40 PM
7808
May 31, 2012 03:24 PM
crf230
May 15, 2009 04:26 PM
Bulls90
May 27, 2008 04:05 PM
wanna6r
Feb 26, 2006 09:57 PM
