What tools and how to remove wheels?
Looking to purchase some tools to be able to repair a flat on the trail for my 2006.
1st. i know the axle nuts are 27mm/22mm for the rear & 17mm for the front. do i need both the 22 &27mm for the rear or do i only need the 22mm? do just remove the 22mm and the axle slides out? or do i remove the 27mm?
2nd, 3 tire irons
3rd, tubes, 3x 21 front 4x18 rear?
4th: tubes or a patch kit?
2nd, 3 tire irons
I use 19&27mm and a pair of these to hold the axle side https://www.knipex.com/index.php?id=...8&groupID=1500 the 86 03 150 is the size I have.
You will also need a 10mm wrench or socket for the front pinch bolts. Slime patch kits are available just about anywhere or got to a bicycle shop.
