Valve size?
Old Jun 18, 2010 | 06:50 PM
FlyingFinn's Avatar
Nice to see other people here that are interested in these same questions!
According to Kevin Cameron (there's no other motorcycle performance wizard and engine tuner I'd trust more than him) in a properly sized exhaust system the size of header tube should be determined based on exhaust valve-open area. This of course assumes that the valve-open area is properly chosen for the cylinder size and "engine tune".
There is "wiggle room" around the theoretical optimum header diameter to slightly push the engines characteristics one way or another, but there is optimum size that gives highest torque peak. (forget about the RPM of that torque peak for now).
Valve-open area is defines as circumference of the exhaust valve x valve lift x number of valves per cylinder.
So, at least for the 300R engine, the valve-open area can be calculated as;
25mm x Pi x lift x 2.
I don't know what the lift of the stock cam is but I'd be surprised if it's more than 0.3", so I'll call it 7mm.
Then valve open area becomes 25mm x Pi x 7mm x 2 = 1100mm^2
Mr. Cameron gives a rule of thumb estimate for the optimum header size as:
header cross section = 1.16 x valve-open area.
1100mm^2 x 1.16 = 1275mm^2
From that we get the ID = 40mm.
That is for 7mm valve lift and 25mm valve dia.
The persistent rumor out there is that KLX250S uses smaller valves than the 300R. If the valves were say 2mm smaller the optimum header for 23mm exhaust valves would be still 38mm.
Mikko
Old Jun 21, 2010 | 05:45 PM
Ranger Ron's Avatar
Originally Posted by TNC
Just points out that old saying about not believing everything you hear on the enternot.
I'm guessing that was directed at me.
I stand corrected and apologize for posting incorrect information.
Ron
Old Jun 22, 2010 | 12:04 AM
Ron
Not directed at you, Ron. I've seen that stated more than once on different threads and different forums, and I've been guilty of quoting it at least once myself. Hardly the end of the world, and I'm glad the correct info has come out. I used the term "enternot" purely in a joking manner, as I think quite highly of the internet overall.
Old Jul 2, 2016 | 07:00 AM
Subseageorge's Avatar
Default Is Bill Blue still in business?
Originally Posted by b_joannblue
Hello All,
The KLX250 & KLX300 have the same size valves in them I=39 MM E=25 MM. Kiblewhite makes a O/S intake valve for the KLX 250 it is 30 MM it is only 1 MM larger than stock. There isn't very much room for O/S intake valves. I recently installed O/S valves in the head on my KLX 351 also had the head ported it made some difference the engine revs a bit quicker now also installed a TM36 pumper carb that made a big difference but the gas milage suffers now. Now have 34 HP at the rear wheel using a experamental exhaust.
Bill
Bill.
Are you still modifying heads for the KLX ?? Do you have a new email address ? I want to buy a ported head.
Thanks.
Old Jul 2, 2016 | 11:41 AM
Old Jul 2, 2016 | 03:15 PM
Klxster's Avatar
Nice resurrection KLX678, I memorized Bill's "34 hp"post long ago but could never have found it.. This is equivalent power levels to a stock KX250F..
Old Jul 3, 2016 | 11:47 AM
Thanking the wrong guy. Subseageorge asked.
Stashu
Nov 17, 2011 02:20 AM
doug1
Dec 31, 2010 05:13 PM
steve10
Apr 17, 2008 03:56 PM
krashman71
Ninja 250R
Jun 7, 2005 03:15 AM
