valve clearences tight or wide
Old Mar 29, 2011 | 12:37 AM
yea i got the hot cams shim kit also.
Old Mar 29, 2011 | 12:44 AM
David R's Avatar
All four of my shims in the bike are 3.05. I will need 3.00 for the next adjustment. Mine are within spec but on the tight side. 5k Miles on the bike. I will check again next winter. Should be another 5 to 10k then I will do them anyhow. Its nice I know what is in there now from doing the 351.
David
Old Mar 29, 2011 | 02:37 AM
T_i_G_e_R's Avatar
cool looks like I made the right move
Old Mar 29, 2011 | 09:55 PM
Powershouse's Avatar
I've had good luck bringing shims to the local bike shops - mechanics will usually swap from their stock to give you the shims you need.
I really like the valve adjustment kit that the ST Owner's Club put together. It has a variety of shims, micrometers, angled feeler gage, DVD with instructions, shim size calculator...everything a guy needs to tackle the job. It is a traveling loan thing that gets passed around among the members as needed.
Old Mar 29, 2011 | 11:53 PM
ol'klx-er's Avatar
That's great comraderie. Really cuts the costs.
There's a couple of sets of doohickey tools (KLR) that have "seen" a lot of the country by way of members of another forum.
Old Mar 30, 2011 | 08:31 PM
I've never heard of anyone bending or burning a valve from being too loose on the clearances.
The only real risk from loose valves would be if the valves were really sloppy on a shim over bucket design where a shim can be spit out if too much clearance and some valve float occurs. But that was a rare circumstance. I heard of it on high rpm Z1 engines back in the day, drag racers and road racers could spit shims out if the valves floated,
Heard of a lot more burnt or bent valves though. Even burnt my exhaust by being too tight.
Highbeam
Jul 6, 2015 10:42 PM
djchan
Oct 17, 2012 01:50 PM
cegusman
Oct 6, 2012 05:38 AM
WHIP-N-DIP
Jul 2, 2012 05:32 PM
SAMCAR305
May 3, 2007 08:40 PM
