Upper Cylinder Clicking Noise
Old Sep 12, 2011 | 01:55 PM
Post's Avatar
Default Upper Cylinder Clicking Noise
I have a new noise in the upper cylinder area. It is not the valve clearance or the cam chain. Any suggestions? It actually sounds like a loose valve clearance, but I have checked the clearances 3 times and all 4 are well within specs. It uses no oil and does not smoke. 18000 miles.
Old Sep 12, 2011 | 02:04 PM
You may be right about the cam chain, but how did you eliminate it as the source of noise? This is the classic "odd" sound that this engine will make in many instances. Otherwise it's a rather quiet motor.
Old Sep 12, 2011 | 02:45 PM
Hey post, first of all welcome to the forums, if you want you can give us a proper introduction when you get a chance. As far as the noise, its probably the cam chain rattling. Get the manual adjuster and you will be a happy camper. What year is your bike?
Old Sep 13, 2011 | 04:29 AM
2007 Green Machine's Avatar
Wow, 18000 miles! Keep it going.
Old Sep 13, 2011 | 12:00 PM
linkin5's Avatar
The cam chain could still be your issue as you cannot tell by looking if your tensioner is bad, The sign of a problem is alot of noise comming from the top of the engine.
Old Sep 13, 2011 | 04:28 PM
Post's Avatar
Default Cam Chain
First, thanks for the replys. I must reconsider the cam chain. I will order the manual adjuster today and when it is installed, write back with the results. I am planning on a 2 day AMA off road run with the Arizona Trail Raiders in a few weeks. I really need the bike to preform to its potential.
Old Sep 13, 2011 | 09:28 PM
09'Kawi250s's Avatar
dang! im at 16900 and the cam chain just makes noise. and it burns a little oil not to bad though.
Old Sep 18, 2011 | 01:42 PM
Post's Avatar
Default Upper Cylinder Noise
Members,
Wow, I cannot believe that I got the speedy responses from the group. Not only that, but you were able to diagnoise the problem. I ordered the Krieger cam chain tensioner. It is installed and bingo, no more clicking noises! Awsome..... and Thank you very much. I am off to Colorado next week to enjoy some fall color around Ouray. I will also watch the forum in the event I can contriute.
Don Taylor
Chandler, AZ
Cowasaki
Aug 25, 2014 01:52 PM
Hubert2012
Ninja ZX-7R
May 22, 2012 12:12 PM
09klx
Mar 11, 2012 02:25 PM
shox rox ice
Feb 8, 2008 12:33 PM
FuryofGreen
Aug 24, 2006 06:26 AM
