Trakmaster street pressure
Old Feb 10, 2012 | 02:17 PM
cegusman's Avatar
Default Trakmaster street pressure
For those that are running Trakmasters. What are you running the tire pressure at on the street?
Old Feb 10, 2012 | 02:25 PM
tom edison's Avatar
I have the Trakmaster 760 on my rear wheel, I run it a 18 psi.
Old Feb 10, 2012 | 02:28 PM
cegusman's Avatar
Cool Was a little worried I was running it way to low.
Old Feb 10, 2012 | 02:40 PM
treerat's Avatar
22 f&b
Old Feb 10, 2012 | 03:32 PM
linkin5's Avatar
I wasn't running a rim lock and lost a valve stem at speed on asphult with 14 psi in the rear. I have a rim lock now and run 15 psig.
Old Feb 10, 2012 | 03:45 PM
I notice you're here in Texas also. With our temps, and if you're running tubes, you might want to stay up around 24-25 with knobbies for any highway running for more than just a few miles. However, since you're running knobbies, I'm guessing you're not cruising over to Galveston at highway speeds. Knobbies squirm more and that produces more heat. Couple that with tubes and you might either blow a tube or at least kill the tire a lot sooner with any decent pavement mileage. I think this would only surface during our summer months, but depending on how, when, and where you're riding on pavement, it's just something to keep in mind. I realize most of us with full knobbies...even DOT models...aren't droning on for long highway miles in the heat, but since it wasn't mentioned, it's just something to consider. It gets hot down here. Remember last summer?
Old Feb 10, 2012 | 04:13 PM
12psi all the time.... just careful on the street.
Old Feb 10, 2012 | 04:30 PM
cegusman's Avatar
I do end up on the road quite a bit, just to get to the trails or our meets. We have a meet every Tue where I have to ride the freeway 26 miles to get there, 70-80 MPH. Did it last Tue with 15psi up front and 18psi in the rear. Never had any issues, still grabbed good on the tight curved paved bike trails we were riding and I was not taking it easy. Freeway ride it handled fine other than the severe need to balance my tires. Thinking of swapping to my Kenda K761's for now.
Old Feb 10, 2012 | 04:47 PM
I try to ride somewhere around 25 psi on the pavement with the *****. Not very particular with exact pressures, as long as I'm above 20 psi or so. I recall others posting that **** wear on pavement can be odd and uneven at lower pressures.
Then I'll air down when I hit the trail to somewhere around 11-13 up front and 12-15 in back.
FM_Thumper
Jun 12, 2008 03:43 AM
djmerullo
Jun 2, 2008 06:06 PM
poodlenuts
Jan 18, 2008 03:03 PM
bkkwolfe
Jan 9, 2006 08:50 PM
c10
Feb 12, 2005 12:00 AM
