Trailtech Headlight and black plastic
Old Nov 14, 2011 | 08:41 PM
T_i_G_e_R's Avatar
Default Trailtech Headlight and black plastic
I love this black plastics look.. what do you like the stock look or the black?.
Old Nov 14, 2011 | 10:03 PM
That looks nice.
I'm a fan of the Trailtech headlight. Have one on the KLX. I need to figure out how to wire it so both lights are on with the high beam setting.
Old Nov 14, 2011 | 10:11 PM
T_i_G_e_R's Avatar
irdr. all you have to do is splice two wires together.. I did mine inside the highbeam switch, but if you can figure out which wires they are you can do it without opening up the switch.. you splice the hot wire with the low beam, then low beam is always on even when you switch to high beam.
Old Nov 15, 2011 | 01:41 AM
BleednGreen68's Avatar
I think the motor fell over in the frame haha.
Old Nov 15, 2011 | 02:56 AM
T_i_G_e_R's Avatar
Yea the motor is backwards and tilted back.. its weird.. going to have to pull the entire motor out of the bike just to check the valve clearences
Old Nov 15, 2011 | 05:27 AM
turnsleft's Avatar
Yours looks sorta like this one cept clean.
Old Nov 16, 2011 | 12:16 AM
Wonder who was in charge of the design team when they finalized that design haha. Other than that looks like a pretty sweet machine.
Old Nov 18, 2011 | 10:31 PM
T_i_G_e_R's Avatar
yea I dont know bleedn green, alot of the bike is backwards.. they seem to have gone out of their way to do things the opposite of what you expect.. I think alot of it is KTM influenced anyway.. those europeans are weird
Old Nov 19, 2011 | 12:50 AM
wildcard's Avatar
That wouldn't matter if it was a KTM, by the time the valve need adjusted the motor is shot anyway...
ZING !
Old Nov 19, 2011 | 01:09 PM
T_i_G_e_R's Avatar
It is a KTM. Same head, valves, valve guides, piston, ring, cylinder, valve springs, cam, valve cover, its a KTM engine backwards, tilted back, and with a diff oil pump and crank case.
jhoffy22
May 26, 2016 07:48 AM
DamageInc4x4NY
Sep 3, 2013 03:05 AM
work
Mar 13, 2012 10:15 PM
CousinLarry
Nov 21, 2008 05:33 AM
markturbo
Jan 8, 2007 11:48 PM
