Trail tech vapor for KLX250
Old Jan 12, 2014 | 03:16 AM
kennysupermoto's Avatar
Default Trail tech vapor for KLX250
Im planing on buying a trail tech vapor, im not sure what model to buy. Any specific model for klx250s 2006?
Old Jan 12, 2014 | 05:34 PM
38super's Avatar
The basic unit is the same for everyone, most kits require cutting a radiator hose for water temp (good place for a leak). You can order a water temp sensor form Trail Tech that will screw into the bleeder bolt on your radiator. The panel mounting kit is for 7/8" bars only.
Mounting the speed sensor can be fun, don't be afraid to drill another hole on the mounting flange for fitment/magnet alignment. I need to load a pic in my PB account that shows a KLX300 installation.
Be sure to route wires to prevent snagging or crushing.
BTW, use heat shrink tubing when you wrap the tach wire. Much better than electrical tape.
Good unit, just wish the back lighting was red for night riding.
Old Jan 13, 2014 | 04:02 PM
Thanks a lot BTW do know the model number?
Old Jan 16, 2014 | 03:21 AM
38super's Avatar
Manufacturer Part Number: 75-200
Not sure where you're located, did some riding like that when I was stationed in Thailand. During 'Water Festival' my buddy was following a truck full of kids. They would hold the bottom off plastic bags full of water and douse everyone they could. Well, one kid let go of a full bag and it nailed my buddy in the chest. If his legs hadn't caught the bars, he would've rolled off the bike. Should've seen the kids cheering when he saved it.
Old Jan 16, 2014 | 02:44 PM
Sounds fun and dangerous well wtb the part number 75-300 i checked on their site too
btw this is how my digital board looks like, so will the model number 75-200 fit?[Imgur](https://i.imgur.com/OFhVtT6.jpg)
Old Jan 16, 2014 | 03:53 PM
38super's Avatar
Hard to tell from your pic, often depends on available space behind the number plate. If the provided bar mounts don't work, then you'll have to improvise a mount. I use 1/8" thermo form plastic called Kydex. Similar material is available. It's simple to form with a heat gun. Watch the mounting angle, the face plate reflections will blot out the LCD display.
If you want to keep neutral, turn signal and temp indicators then get the Trail Tech bezel. It clips onto the Vapor.
My Vapor kits were from Epay, still had to get temp sensors and bezels from Trail Tech.
dan888
Apr 23, 2011 05:05 PM
IDRIDR
Nov 7, 2010 06:08 PM
maineack bob
May 2, 2009 06:44 PM
MaverickAus
Dec 30, 2007 04:15 PM
mikem1965
May 15, 2007 01:42 PM
