Tm36-68?
Mine came delivered with a 1.0 air jet, but I went to a 0.9 to suite my setup. I think I recall Dan Moore saying he thought his didn't have anything in the air jet hole but just didn't see the jet at first. If there's nothing in there, it seems like there should be a jet. The 1.0 air jet is the standard delivered jet for this carb in its generic setup from Mikuni. If the hole without a jet was machined with a 1.0 hole, then the larger jets would be ineffective. Maybe an e-mail to Sudco or such would answer the question.
Where in the throttle position/range is the rich condition? Can you describe how you concluded it was rich?
Main Air Jet passage should be open, no jet or plug installed. The Pilot Air Jet passage should have a jet, 1.0 is stock.
Ah, I thought he was talking about the PAJ.
Found my prob, large sludge deposit in the PAJ port. Just need to sort thru the hanging idle.
I don't think the MAJ port is drilled thru.
edit:
Main -132
Pilot -15
PAJ - 1.1
Thanks for the help, just crack the throttle no more than 3 kicks.
edit:
Main -132
Pilot -15
PAJ - 1.1
