too rich...too lean...how do you know for sure?
Old Mar 27, 2007 | 04:31 AM
JB1's Avatar
JB1
Default RE: too rich...too lean...how do you know for sure?
Thanks YYY.GUY and Snal, Im gonna try doing that procedure. I just wanna make sure my bike is running optimal as best I can on my own.
Old Mar 27, 2007 | 09:15 PM
Team FTB's Avatar
Plug chops are decent indicator of jetting. Its just getting to our plugs to read, clean, reinsert and try again is a bit of a pain.
Anybody got any good, detailed links that go into bike behavior to assist in jetting? Particularly the Pilot and needle jet settings.
Here is a tidbit I ran across but others would be appreciateed:
how to confirm your pilot circuit setting
seems like the most common jetting issue that comes up are pilot circuit related.the following is a sure method to choose the needed changes.
with the bike warm and idling turn the fuel screw in till the idle drops/misses.then go back out till the idle peaks/smooths.
this should happen between 1 and 2.5 turns on a fcr carb and 1 and 3 turns on a cv.
if you end up at less than 1 turn you need a smaller pilot jet.more than 2.5 (or 3 turns on a cv) you need a bigger pilot jet.
choose the appropriate size and retest.
Old Mar 27, 2007 | 10:51 PM
britboard's Avatar
found this in the electronic ether, dont know if it helps but here it is,
http://members.aol.com/roundr1/CVK40.html
not for the right size carb i know but the same principles apply.
Simon L
Brieninsac
Feb 26, 2012 05:57 PM
oldskooldubbin
Apr 7, 2010 02:15 PM
chris72a
Apr 26, 2008 02:23 PM
fireslayer
Aug 23, 2006 03:02 PM
kaw98zx6r
May 17, 2006 06:07 AM
