Tire Pressure
Old Feb 11, 2007 | 10:56 PM
Fishfinder's Avatar
Default Tire Pressure
I have my tire pressure set at 13F and 14R. (Stock Dunlop 603's and no rim locks) I ride in mostly dry and rocky terrain. I understand that the wetter looser the conditions you should use less pressure. I don't have that much experience to relate to and was wondering what everyone else is running and how it is working for them.
Old Feb 11, 2007 | 11:21 PM
mmatz's Avatar
Default RE: Tire Pressure
I would recommend around 16 - 20 PSI. This should be ample and not require rim locks. If you want to go lower then look into rim locks. I don't think this bike has enough torque or power hit to worry about it to much though.
Old Feb 11, 2007 | 11:39 PM
jsac's Avatar
ORIGINAL: mmatz
i had rimlocks installed a month or so ago.. i dont think their absolutely necessary torque wise with this bike but if ur runnin low pressure, i dont think itd be hard to hit a rock etc and spin a tire if ya came down the right way after catchin a little air or loftin the front tire... guess id rather be safe than sorry.
Old Feb 11, 2007 | 11:43 PM
DirtSurfer's Avatar
+ 1 on the recommended tire pressure.
My dirtbike tires had a recommended 15 front 15 rear for track riding but they had rim locks as well so we would drop them down to 10 f, 12 r when riding in deeper sand.
I would think the min pressure you would want, ex rim locks is 15 F&R, but I would think that for the type of riding your doing, 16 F and 18 or 20 rear should be spot on....
Old Feb 11, 2007 | 11:52 PM
mmatz's Avatar
Oh, and don't forget to remove the valve stem nut at the rim. This allows for some slight movement without ripping the stem loose from the tube.
Old Feb 12, 2007 | 07:24 PM
incabiker's Avatar
So if you don't have any rim locks and don't plan on getting any what would be the safest bet for the road and the dirt?
Old Feb 12, 2007 | 07:31 PM
cwgoff's Avatar
ORIGINAL: incabiker
I would think you would run full tire pressure (~ 20psi) plus loosen the valve stem nut as mmatz suggested just to be sure. I figure if you ran like that, there is very little chance you are going to rip a stem off.
thatguy331
Ninja 500R
Jun 20, 2007 04:18 PM
konacoiler
Jul 20, 2006 03:00 AM
Funkdock
Apr 22, 2006 01:43 PM
incabiker
Mar 27, 2006 05:54 PM
c10
Feb 12, 2005 12:00 AM
