these bikes are more different than the 300's than we actually think
Old Mar 28, 2007 | 09:40 PM
Default RE: these bikes are more different than the 300's than we actually think
Are you sure the front KLX250S rotor is not already floating? It looks to me like it is, i.e., it is not bolted rigedly to the hub. Well, the inner piece is, but the outer piece is connected to the inner piece by those ring buttons which allow some side to side movement, which is what a floating rotor is.
The back rotor looks like it is one solid piece, non-floating, but the front looks to be floating already.
FWIW, both rotors on the KTM 450 EXC are of the non-floating variety, they are both bolted rigidly to the hub.
Old Mar 28, 2007 | 11:53 PM
KLXer's Avatar
Nobrakes: Semi & full float look similar & both use a two piece design with a carrier & a rotor.A semi float basically allows no side to side movement (go press hard on it--its imperceivable at best) but does allow it to expand radially outward, ie when it heats up under hard braking. A full float allows both radial & side to side (axial) movement. If its full float there will be no question as with no force at all the disc should slide back & forth on the buttons. Manufacturer's even will say their rotors are full floating when in reality they are not.
Old Mar 29, 2007 | 12:27 AM
Thanks for the clarification.
Old Mar 29, 2007 | 03:13 AM
IchWarriorMkII's Avatar
ORIGINAL: Iowaguy
the ONLY reason i bought the 300 rotor was i like the way it looks over the oem rotor. yes, it is semi-floating but the 300 one looks more rugged and racey. now i'm starting to wonder if i'm trying to make this bike into something i should've bought in the first place- a true MX bike. but then i think about just riding it anywhere where a MX bike would sit in my garage until i trailered it somewhere to ride it. then that takes me back to selling it and buying a new Husky. i need a therapist.
Just need to ride it more!
Old Mar 29, 2007 | 08:19 AM
ORIGINAL: IchWarriorMkII
ORIGINAL: Iowaguy
Damn bro you are becoming the klx "bitch" make up your mind....put some miles on the bike......are you still less than 1k miles........if so ride it and beat it up a little.
Frontier
Nov 17, 2009 04:46 PM
Dready
Oct 22, 2009 11:58 PM
walight01
Sep 11, 2006 01:31 PM
vfrpilot
Aug 30, 2006 05:04 AM
motoguy128
Apr 14, 2006 06:27 PM
