Testing the 34mm CVK with a/f meter
Old Nov 5, 2014 | 05:19 PM
zomby woof's Avatar
Here is a little more info that I found while looking for something else
https://www.kawasakiforums.com/forum...82/#post425517
Old Nov 5, 2014 | 07:10 PM
Richard Avatar's Avatar
Back then you said his 135 DJ main was the equivalent of a Keihin 145? That'd be way too big a Keihin main jet. I think we've discovered since that it's hard to cross ref the DJ to K main jets.
I say just buy bigger Keihin main jets from the aftermarket to begin with and possibly get a better quality controlled jet too boot.
Old Nov 5, 2014 | 08:52 PM
zomby woof's Avatar
The info we had then was the comparison charts that have been posted here in the past, like the one from Jets r us. I guess we know now that they're wrong.
I wish I had saved my money and not bought the DJ kit. I'll probably pull it out and go with the Keihin parts. I wonder if it's OK to drill this slide, instead of using the spring?
Old Nov 5, 2014 | 09:40 PM
Zomby -
It's interesting that the comparison charts are based on orifice diameter, but that there's such a difference in flow between the Keihin and DJ.
The carbs are essentially the same if not identical, aren't they? Others have installed the 2206 DJ kit in the 2009+ carb and drilled the slider. Us KLR riders will also drill the slider without adding any kit. If you don't like it, fill with epoxy and re-drill a hole of original size.
Old Nov 5, 2014 | 11:55 PM
Meaning drill the Kaw slide? Everyone does; haven't heard any complaints.
I went as far as rounding off the inlet port entrance so air could flow in faster to raise the slide.
Old Nov 6, 2014 | 08:05 AM
zomby woof's Avatar
From memory, the slide and diaphragm are different between my 07 and 09, so I wondered if there might be a difference in the holes.
Old Nov 6, 2014 | 08:55 AM
Seems to be the same part number for 07 and 09 slides as far as I can see.
Valve,Vacuum [16126-1339] for Kawasaki Motorsport | eReplacement Parts
Old Nov 6, 2014 | 11:46 AM
  #28
Broussard's Avatar
Default Richer needle?
Anybody have a suggestion for a richer needle than the Dynojet for the stock carb?
I should probably just buy a TM36, but I already feel a little silly about how much $ I've sunk in this bike...
Old Nov 6, 2014 | 06:02 PM
  #29
N1TC needle is popular
16009-1912 NEEDLE-JET,N1TC $24.60
Old Nov 6, 2014 | 07:27 PM
  #30
Broussard's Avatar
Is this one adjustable?
