temp gauge without replacing stock speedo?
Old Jan 3, 2018 | 05:20 AM
horror_fan's Avatar
Default temp gauge without replacing stock speedo?
Is there any temp gauge on the market I can install on the klx without replacing the speedometer?
I'm looking at the trail tech gauge and the thermo bob.
I don't want to replace the speedo and I don't want to change the operating temperatures of the engine.
I just want to measure the temp while riding
..so are they're any other options?
Old Jan 3, 2018 | 10:50 AM
s10gto's Avatar
Yes. Trailtech TTO temp meter. Easy to install and works perfectly.
Old Jan 3, 2018 | 02:49 PM
There are some other temp gages out there, but I agree with s10gto. Go with Trail Tech.
On the ThermoBob, you can get other termostats if you want to work with the ThermoBob unit, but what watt-man supplies is probably just right. Talk to him about your concerns.
Old Jan 4, 2018 | 03:04 AM
outrecording's Avatar
In addition, there is also a coolant cap with temp gauge. But probably not as accurate as the above gauge and not as convenient to look at.
Old Jan 4, 2018 | 08:44 PM
horror_fan's Avatar
yeah heard of those not being accurate... I guess for my application I don't really need an accurate results.
horror_fan's Avatar
sick thanks for the photos.
what size for the hose? also where did you get the blue style? Im looking on the website and all they got is black.
Old Jan 5, 2018 | 12:18 AM
s10gto's Avatar
22mm
https://www.trailtech.net/7500-3060
Old Jan 5, 2018 | 05:10 PM
horror_fan's Avatar
this one comes with the gauge right?
I'm going to have to many gauges on my bars lol I just bought an 02 sensor as well.
Old Jan 5, 2018 | 07:27 PM
s10gto's Avatar
No that's just the sensor you will get when you select 22mm.
Old Jan 5, 2018 | 07:29 PM
s10gto's Avatar
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.denniskirk.com/trail-tech/black-tto-digital-temperature-meter-22mm-radiator-hose-sensor-742-eh2.p4001087.prd/4001087.sku&ved=0ahUKEwjLmcrR1MHYAhUGkeAKHSR4AYkQF gifATAN&usg=AOvVaw2uV9F2nn3q6w9TlIG2fp5F
creighton99
Jan 25, 2018 03:41 PM
warmaster123
Oct 2, 2017 08:38 PM
mcwee68
Oct 12, 2015 10:55 PM
korax123
Ninja 250R
May 29, 2007 06:55 AM
eclipsehunter2001
Oct 26, 2006 12:24 AM
