Surging and related issues
Old May 17, 2013 | 10:36 AM
zippets's Avatar
Originally Posted by ianmcdca
Just thought I'd mention that today I removed that plug covering the fuel screw...what a pain in the ****....had to remove the carb to do it....
Sadly, adjusting it didnt make the difference I thought it would. Today the surge was more noticeable AND it was colder out (15celcius). So, is that a too rich or to lean issue? This is the surge while at speed and over 3000rpm.
well i believe it is too lean
yesterday i was running out of gas ( as you know your bike leans out when the happens) my bike was surging at 70 mph just before.
I would go up on your main jet it sounds like you still stock
Old May 17, 2013 | 02:23 PM
ianmcdca's Avatar
Ya I think it`s time to try that...I guess if I'm going to do the main, I might as well to the kit?
I was hoping to ride it for a season without doing any customizing, but I guess it's a question of whether I can handle the surge.
Last question....I haven't seen any posts/replies on this or other related topics suggesting timing. Maybe thats another post, but just thinking out loud here. Maybe as the the bike breaks in, the cam chain slacks a bit from the auto cam adjuster not working properly?
Just a thought.
Thanks again for all the replies.
Ian
Old May 17, 2013 | 02:49 PM
zippets's Avatar
Just a thought.
Ian
mine surged before i did the jets
purchase the DJ jet kit stage 1-2
only do the stage one until you jet a pipe and air box
Old May 18, 2013 | 11:36 AM
ianmcdca's Avatar
Ya think I`ll try that DJ kit...fuel screw does little if anything.
Thanks,
Ian
Old May 18, 2013 | 06:33 PM
Thanks,
Ian
The OEM needle has a terrible emissions profile designed into it, and that can aggravate surging when everything else isn't perfectly set up. The DJ needle will go a long way to improve throttle response and cruising smoothness.
KLXer
Dec 9, 2007 03:04 PM
mataleao
Sep 25, 2006 08:32 AM
wolfspiritt
Classic Sportbikes
Sep 1, 2006 08:07 AM
konacoiler
May 22, 2006 09:17 AM
ryninger
Nov 21, 2005 07:02 PM
