Stuttering
Old 11-16-2016, 10:42 PM
texas123's Avatar
Default Stuttering
Just picked up a 2014 KLX250 with 800 miles on it, now has 2k miles & I'm having an issue while on the highway. The bike starts up fine & drives like it should, It rides fine around town & off road; except for highway speeds. It seems to loose power for about 1 second & then surges power for a few seconds & just seems to happen around 40 - 60 mph, over & over again. It does this the whole time I'm driving it on the highway. Almost like it's running out of gas momentarily over & over, but just for a second. It's been doing this for about 1k miles & getting slightly worse. Doesn't seem temp related & don't think fuel level affects this.
Anyway, I'd appreciate any help.
My altitude is 150 ft, Houston area, & temps are 80*.
Also, the tire keeps loosing air & I've changed the tube 2x. It doesn't drop below 17 psi though. First bike with a tube too.
Old 11-17-2016, 01:22 AM
Klxster's Avatar
I'd check the fuel filter - it's inside the fuel tube where it connects to the carb..
Old 11-17-2016, 02:32 AM
texas123's Avatar
Thanks, I'll check tomorrow. Wouldn't that cause problems throughout instead of bogging senation at highway speeds though?
Old 11-17-2016, 01:08 PM
Klxster's Avatar
Depending on your riding style, the largest draw on the bowl could be sustained high speed/relative high RPM highway usage.. So the answer to your question is no/yes/maybe..
Old 11-17-2016, 01:43 PM
ITHAPPENS's Avatar
Float height issue maybe? If the fuel level in the bowl is slightly low it could be momentarily starving for fuel at high throttle settings.
Also wasn't there a ground issue that would cause a slight hesitation? Good luck.
Old 11-18-2016, 01:58 AM
texas123's Avatar
I changed the coolant, scrubed the bike & chain clean, increased the preload and set the damping rates to stock. I'm not sure why, but the pulsing is completely gone and it rides soooo much better now.
I think the chain may have been binding at speed causing the pulsing sensation. It was very very dirty/rusty so I scrubed it with simply green & mass airflow sensor cleaner and a brush.
big-al
06-17-2013 06:33 PM
jdhu
06-09-2010 03:33 AM
mattyw
11-01-2009 09:08 AM
YYY.GUY
Joke section!
06-05-2007 06:52 AM
JFV1134
08-31-2006 04:24 AM
Quick Reply: Stuttering
