Street suspension set-up.
I copied this from another post for reference:
What I would like to know is what the street riders are setting there bikes at?
Bike is set up for motard duty.
If it helps any, I'm 200lbs. dressed for the crash.
The Owners Manual states that the Default settings for the forks and shock are as follows.
Front Forks - Compression = 8 clicks out from fully seated.
Rear Shock - Compression = 16 clicks out from fully seated / Rebound = 12 clicks out from fully seated.
__________________________________________________ _______________________________
The Main klx250R Service Manual states that the Default settings for the forks and shock are as follows.
Front Forks - Compression = 12 clicks out from fully seated.
Rear Shock - Compression = 14 clicks out from fully seated / Rebound = 9 clicks out from fully seated.
