STOP tip-over fuel leaks
Old Aug 12, 2022 | 07:02 PM
LaGrasta's Avatar
Default STOP tip-over fuel leaks
I'd love to say I never tip-over, but… Each time it happens, I have to shake it off so I can quickly lift the bike to avoid losing more fuel than I have to. I recently discovered this Free Flo Vent Hose: https://www.rockymountainatvmc.com/p...1171&idd2=5237
which then lead me to this Billet Vent w/Check Ball:
https://www.amazon.com/gp/product/B00XTTNPLK/ref=ewc_pr_img_1?smid=A1UCBIFNI71X4U&psc=1 https://www.amazon.com/gp/product/B00XTTNPLK/ref=ewc_pr_img_1?smid=A1UCBIFNI71X4U&psc=1
What fuel tank vent tube should one of these attach. Do you think it will work? if so, it would be a great mod, wondering why factory doesn't do this.
Old Aug 13, 2022 | 03:04 PM
tooter's Avatar
I put one of those little check valves on mine and it works fine.
Old Aug 13, 2022 | 03:39 PM
LaGrasta's Avatar
I’m not speaking of the cap. I’m intending to put it on the end of the vent hose. our bikes don’t have your cap unless you’ve swapped fuel tanks for an aftermarket
Old Aug 14, 2022 | 03:26 PM
tooter's Avatar
Neither am I.
Fuel tank vent hoses are all the same except for the length. The cap on the end of your vent hose will need to be oriented vertically as pictured for it to work properly. There's a little ball that falls to the bottom of the cap allowing the tank to vent when it's in the upright position. You can hear it rattle inside if you shake the cap. When the bike tips over the ball moves to the top blocking fuel from leaking out.
Old Aug 15, 2022 | 03:11 PM
LaGrasta's Avatar
thanks tooter. Do you know what hose it is on a stock tank set-up? I guess I could tip my bike over and see where it leaks.
Old Aug 15, 2022 | 04:23 PM
tooter's Avatar
Sorry, I didn't keep track of what went where when I removed everything, although I believe the tank vent hose would connnect to the emissions cannister.
The IMS 2.7 tank eliminated two pounds of emissions equipment along with that huge tangle of hoses under the stock tank. Now there is only one hose from the fuel pump to the injector, and one little fuel vent out the top of the cap. I highly recommend the larger tank. I keep gas mileage logs as I use my KLX for daily transportation. I average over 80 mpg which makes the effective range over 200 miles
Old Apr 4, 2025 | 04:10 PM
LaGrasta's Avatar
I finally added a Clarke tank. When I fell over, nothing leaked out as it did with the OEM tank set-up.
It's ironic that they add the smog equipment and vented tank to save the environment. And it leaks fuel all over the ground each time I fall. I then remove the smog and swap to a new take with a vented cap and nothing spills on the ground. Typical bureaucracy, especially in California.
mcrider1959
May 10, 2022 05:45 PM
Hunter1660
May 10, 2013 02:18 AM
flateric
May 3, 2011 10:57 PM
Freeze
Mar 7, 2010 09:19 PM
CJBHM52
Jul 5, 2005 04:56 PM
