Stock carb and 330 upgrade Q
did a 330 kit this spring, as well as the intake, full exhaust, dyna jet stage two, lower gearing, and i also ride 95 percent dirt. the 330 helps a ton down low and climbing. actually every where its noticable, but for me the cv carb set up was way to slow for dirt riding. threw in a 36-68 last night with minimal tuning and pretty much just set the pilot circuit up and went for a rip. WOW! the most noticable mod, hands down, that i have ever done so far. it is like riding a rocket ship. cant wait to fine tune a little bit when the other jets come. try the carb down the road after you break in the big bore, you will not be dissappointed.
zippets, here's the link I spoke of on the PM about the TM36. I'll just post it here with this thread.
https://www.kawasakiforums.com/forum...klx250s-13648/
im at 500 to 900
i know im running my bike richer then most of the forums being @ 132 on the main and 4 slots down on the needle
do you think the carb at stock form would be good for me since most i have seen was leaning the carb out
or did i read the post wrong ?
Thanks i read the post and it seems everyone is about 2500 to 3000 ASL
im at 500 to 900
im at 500 to 900
In the same box will be a flywheel that's been lightened a pound or more
I can't imagine what it'll be like after those additional mods...it zooms through the gears so quickly now - bigger carb and less flywheel effect?
I switched from 14/44 gearing to 13/44 yesterday, and when I banged second gear the front end shot right up! It wasn't doing that with the 14/44..
I'll be keeping that gear ratio but switching to 14/47 (almost the same) to keep a larger diameter front sprocket on it.
This bike just keeps getting faster and faster
