Starter gear ruins engine cases
Old Dec 13, 2012 | 09:42 PM
  #41
Originally Posted by LikesToThump
I enjoy thinking about this much more than my lame interpersonal communication research work at the moment. What your saying is almost the entire accumulation of my progression of thoughts over the last day and a half.
The progressive "egging" of the bushing really got me thinking it was time induced. Could just a bad spot in the bushing and or lubricant.
That bushing (and all the gears in the starter drive train) is only used when the bike starts, and for only two or three seconds. It is not lubricated very well, especially since it is only used at start up. It is lubed while the bike is running , and that will be the only oil in it the next time you fire it up. I had the bushing analyzed because I was going to make a new larger one to fit in the stator cover. I was told that the bushing is an iron based P/M product (powdered metallurgy) The powder is sintered together. Besides being iron based it also has a small amount of copper which may be uses to help with lubrication. The P/M make up has a natural porosity which helps it hold lubricants.
Old Dec 13, 2012 | 09:50 PM
  #42
LikesToThump's Avatar
Originally Posted by dan888
That bushing (and all the gears in the starter drive train) is only used when the bike starts, and for only two or three seconds. It is not lubricated very well, especially since it is only used at start up. It is lubes while the bike is running , that will be the only oil in it the next time you fire it up. I had the bushing analized because I was going to make a new larger one to fit inthe stator cover. I was told that the bushing is an iron based P/M product (powdered metallurgy) The powder is sintered together. Besides being iron based it also has a small amount of copper which may be uses to help with lubrication. The P/M make up has a natural porosity which helps it hold lubricants.
I understand powder metallurgy bushing... but what do you think caused the wear then if not friction? Or are you saying the bushing possibly fractured from impact... maybe a piece of its in case...
Old Dec 13, 2012 | 09:51 PM
  #43
I'm 99.9% certain that the damage was caused by the engine trying to basically run backwards a bit. The piston being forced backwards, for whatever reason, ( my guess pre detonation ) and the force being mainly transferred to the small idler gear in the starter gear train. I also think, that the hiccups damaged the idler gear shaft, and it eventually ate through the bearing. At one point I'm sure that the hiccup force was enough to crack the boss on the engine case side. Eventually the bearing and the idler gear were so damaged that the stater gear train slipped and I was stuck out in the woods and had to bump start the bike to get back to the truck.
Pretty sure that's what happened.
I'll post some more pics later
DAn
Old Dec 13, 2012 | 09:55 PM
  #44
I understand... but what do you think caused the wear then if not friction?
I think the shaft of the gear may have been damaged in the hiccups and subsequently wore through the bushing. The hiccups were violent enough, at times, that I wouldn't be surprised if the bushing had gotten deformed.
Old Dec 13, 2012 | 09:59 PM
  #45
Pretty sure it didn't fracture. It's possible that small chips may have broken off of it, but for the most part it wore through. I will post a pic of it , and some other stuff later tonight.
Old Dec 13, 2012 | 10:49 PM
  #46
Fascinating deal, dan. I think it can be traced back to the upside down track experience your bike went through. It's probably been harboring resentment all this time and just waiting to pounce for payback.
Old Dec 13, 2012 | 11:12 PM
  #47
It has surprised me over, and over, each time i picked it up an rode off. If it were something like one of my crashes that caused the break down I would feel better about it.
I am going to go clean up my workroom. Got my first box in the mail today. A grab bag off of eBay that had the idler gear in it. Got the gear and a pile of stuff for $20 +s/h vs about $60 + s/h for just a new gear.
Old Dec 13, 2012 | 11:40 PM
  #48
Grab bag off of eBay
got it
"new" idler gear from grab bag.
Stator cover w/worn bearing
bushing removed from stator cover, note that it is still intact at the bottom.
My idler gear, note shaft galling which has worn through bearing.
stator cover without bushing, note worn spot on cover. Name:  IMG_1814.jpg
engine case on eBay
Old Dec 14, 2012 | 01:46 AM
  #49
NEWPARTSRULE's Avatar
WOW ! Mellow out with the starts, man. Hey Dan, looks like you're getting things lined up.
Old Dec 14, 2012 | 02:04 AM
  #50
You're a resourceful bugger, dan...and cheap.
