Speedo off about 10%
Old Jul 5, 2017 | 03:12 PM
afdfirefighter's Avatar
Default Speedo off about 10%
I have heard this is somewhat common on them. How do I go about calibrating it to be correct? Thank you in advance. Looking forward to browsing the threads and getting this bike set up. Bought a 2012 with 481 miles on it.
Old Jul 5, 2017 | 04:03 PM
glevy's Avatar
Congrats on the new bike, its a normal issue for all KLX owners, I just live with it as 10% is easy to calibrate in your head.
110 speedo = 100 real
77 speedo = 70 real
33 speedo = 30 real
If it bugs you, check out the following:
SpeedoDRD
SpeedoDRD
Old Jul 5, 2017 | 04:46 PM
The only problem with figuring it in your head is the miles still get added at a 10% higher rate too.
Old Jul 5, 2017 | 05:10 PM
Check your odo carefully. Some are more accurate than the speed indicator.
Old Jul 5, 2017 | 05:14 PM
Good call. I will check the odometer. I figured it was calibrated off of the speedo.
Old Jul 5, 2017 | 05:35 PM
Seems the Japanese are good at having the speedo off by about 10%, but the Odo being near spot on.
Old Jul 5, 2017 | 08:06 PM
dunerdr's Avatar
I had the same problem till I found out about the 12 Oclock Labs speedo fix. After I installed the easy to install device on my 2009 KLX250S, I'm now at or near 100% correct according to my GPS. I wish I had done this when I first got the bike. I bought mine from Motomummy.com.
https://www.motomummy.com/chain-kits...FaN_QgodDkMAHg
Old Jul 5, 2017 | 09:19 PM
sphen's Avatar
^^^ this
Old Jul 5, 2017 | 11:50 PM
durielk's Avatar
It is really easy, what ever speed it says... your going slower!
Old Jul 5, 2017 | 11:57 PM
Saves money and points on license if you pass a cop at 10 over...
