Should I go back to stock pilot jet? need help
Old Feb 8, 2018 | 02:30 AM
horror_fan's Avatar
Originally Posted by Klxster
OH, ok.. so finally a good description of an issue - Quote: if I have it set at 1.3-5 rpm it will start good but then move up to like 2k rpm ...so ill turn it down ...then the bike owns start cause the idle is too small ....!!!FFFFF
Is is possible he is adjusting his idle speed with his fuel screw?
How bout setting the Fuel Screw to 2.5 turns out and don't touch it again for any reason - any at all. (Do this carefully with a properly sized slot screw driver..)
Start the bike and once FULLY HOT with CHOKE OFF, set the idle speed screw to 1300- 1350 rpm..
Enjoy..
If that fails to work, you have bigger problems - problems not associated with fuel screws..
what problems give some examples...
what do you mean adjusting the idle speed with the frign fuel screw? you think I'm trying to adjust the Rpm and idle with the fuel screw?!
Right now the fuel screw is set to 2.25 (which is too rich at idle) and I've just been adjusting the idle speed with the IDLE SCREW
I set the idle speed to 1300 rpm right after it warmed up and after riding it moved up to almost 2k so thats why I decreased the speed ...which made it hard to restart since it was too low.. (this is always how I set the idle speed and air fuel mixture)
I guess I wrote it wrong in my thread.... I meant it moved up to 2k rpm by itself
heres another thing that might be a problem... I will let the bike sit for +1 hour and ill open the gas cap and there will always be a little bit of gas along the filler lip
I gave you the results of setting the fuel screw to 2.5 and 1300 idle speed (idle screw NOT the fuel screw). didnt work out
I think I should swap to a 35 pilot jet instead, inspect the float needle and adjust the float height.
then the carb shouldn't be giving me any problems. maybe could use a tiny bit more air at 1/3-full throttle.
Old Feb 8, 2018 | 06:26 AM
Klxster's Avatar
That is something I think I've read about long ago - the 2k idle when hot.. Or maybe that is something I've run into myself, decades ago... Doesn't matter, what matters is that if you continue to fool with pilot jets, fuel screws, and idle screws, for a problem that does not involve any of them, you'll need to up your meds or go crazy..
You have a fault in the carb. And possibly in fuel delivery from the fuel tank.. Possibly an air leak, Possibly improper venting of the carb bowl or gas tank,, etc etc... Get the float level checked and correct. Make sure the slide is functioning properly and not sticking. Make sure the slide spring is indexed in the cap tangs. Make sure the pilot jet is not clogged and that all its' aeration holes are clear of clogs.. etc. etc etc etc
There are a zillion things a newb might do to cause such a fault.. If you have trouble "breaking your cycle of addiction" (Fuel screw / idle screw / pilot jets, repeat) - Look at your AFR gauge when its' idling at 1300 and again when it has raised itself to 2000 - and realize that none of those three objects can cause the AFR differences you are seeing - their collective IQ is "0" , they cannot even perceive the outside world.
Old Feb 8, 2018 | 01:58 PM
horror_fan's Avatar
first ill make sure if its even raising to 2000rpm
I dont think any of the jets could be clogged I just put the new ones in not to long ago.
the slide could be an issue ...
the float could be an issue too...
I'm just going to bring it to a shop and have the float adjusted and then ask them to check everything else.
Old Feb 8, 2018 | 04:39 PM
horror_fan's Avatar
well I think I found the problem boys
I know I'm a noob ...but I'm assuming this is too low .
dont mind the drain screw. I know.. its an embarrassment
although it doesn't match why I'm getting richer idle readings... if the float was low shouldn't that mean the bike runs leaner?
Old Feb 8, 2018 | 05:09 PM
Okay, here's what you're going to want to do. At least what I did.
Get a can to dump fuel in. Close the petcock, point the hose into the can, open the drain screw and let some fuel out, then point the hose back up. The fuel level should be low. Hold the tube without moving it. Open the petcock and see where the fuel level rises to. Rinse and repeat a few times to where you are getting consistent levels/measurements. Then let us know.
Old Feb 8, 2018 | 05:15 PM
horror_fan's Avatar
Wait nvm ... the first try was with the bike un leveled
heres a new measurement with the bike as straight as possible.
my procedure was , close pet **** drain fuel ... then I setup the hose then opened the petcock.
Old Feb 8, 2018 | 05:26 PM
Good. Now put the hose on the right side of the carb since it appears the carb is not level, with right side lower than the left side.
Old Feb 8, 2018 | 05:43 PM
  #28
horror_fan's Avatar
do you mean should try to get the bike on a little incline ?
the bike is just sitting up straight with the carb on the bike...dont think its necessary to make it more leveled.
heres the new plug after 130 miles
and heres how much fuel I got from a full bowl, looks like more than a bowl can hold but maybe I'm wrong....
Old Feb 8, 2018 | 06:35 PM
  #29
horror_fan's Avatar
update:
knocking went away and bike runs perfect now!
sorry if wasted anyone's time with this mysterious issue.
I set the fuel screw to like 2.1 turns out...and the bike runs good
I know someone said 2.5 turns but it wasn't working for my bike a fully stock 250s with the EPA removed and plugged. and dynojet 116 main with the needle and spacer and 38 pilot.
Old Feb 8, 2018 | 06:41 PM
  #30
If the carb is level side-to-side and front-to-back, you're good. The photo made it look low to the right.
