shock damping too high
Old Aug 6, 2012 | 02:30 AM
stephenmarklay's Avatar
Default shock damping too high
Yes now that everyone is looking
I had both front and year too stiff. I was compensating for my porker 200 loaded body and had the front to like 2 turns and the rears about 5 give or take.
My body had been complaining on my commute so I tried to back them down. I only went to 3 on the front but tripled the year to about 15. Better.
I only say this since some of you may have done this in an attempt to stiffen the suspension and realizing like I did the bike was to stiff.
Carry on.
Old Aug 6, 2012 | 03:31 PM
Blackheart58's Avatar
Stiffer FEELS faster, because there is less control and traction as the tire skitters around. I don't know how the compression spike is on the 2006 model, but, it was HORRIBLE on the 2009. I had it revalved, and it's like night and day better.
Correctly springed, PLUSH, quick-reacting suspensions are my goal...sometimes that requires thinner oils, which can require modified shim stacks, Intertia valves (not available on the KLX, darn-it), etc.
But, I'm NOT a suspension expert. I do pay attention when the experts give out advice, though.
Old Aug 6, 2012 | 05:47 PM
djchan's Avatar
Bad things happen when you compensate for improper springs with added compression damping. It helps with the nose dive on braking but creates a host of other issues. I learned the hard way - 1st thing you do to a suspension is spring it properly. Until that's done, you can't really tell what kind of valving/settings you need.
Old Aug 6, 2012 | 07:04 PM
Yep. I did it to get rid of some of the dive and just went too far. I am commuting on the bike but even so it is much better now. It glides over pot holes as it should.
Old Aug 6, 2012 | 07:33 PM
Malves's Avatar
+1
horizonod
Dec 21, 2008 06:06 PM
mandark
Nov 17, 2008 09:09 PM
open air
Aug 27, 2008 03:58 PM
calamarichris
Ninja 500R
Jan 9, 2007 09:13 PM
rkutzner
May 6, 2006 02:23 PM
