shock adjustments
Old May 16, 2008 | 11:48 AM
cosmickites's Avatar
Default shock adjustments
hey all,
anyone mess with the shock adjustments (front and rear) on the 09? I am 175lbs and wonder what the optimal settings would be.
any advice?
Old May 16, 2008 | 12:08 PM
pie4foou's Avatar
Default RE: shock adjustments
play around with your clickers. they should be on the top and bottom of the forks. and the same with the rear. I'd set the sag first, that was a major improvement in handeling for me. remember when you go to change the clickers, you should count how many clicks it takes untill there closed. Some times the factory settings arent even the same from one frork to the other. Righty tighty, Lefty loosey. lol
Old May 16, 2008 | 12:09 PM
LD Drew's Avatar
Ahhhhhhh., wel my friend, i am 145 lbs, 5'10, . and im riding the 09 at different Rear level settings to see if i can feel the difference., i ride on the road 80%and i m riding fairly loose cause im light..., i havnt really noticed any diff in the rebound in the rear. i havnt even touched the front susp . ,dont really knw how to set that up.,,. ., let me knw if you come to any Conclusions !!.
Old Jun 2, 2008 | 01:50 AM
SavageKen's Avatar
pie4foou, How correct you are I finally got a stand so I could Adjust the compression on the front forks. the manual says factory setting is 8 clicks from fully seated well one of mine was set 11 clicks from fully seated and the other was set at 12 clicks from fully seated. I do not know who Initially sets them factory or dealership. So people might want to check them just to be safe.
Ken
motogprocks
Sep 21, 2012 05:10 AM
mandark
Nov 17, 2008 09:09 PM
incabiker
Mar 2, 2006 10:05 PM
grafhky52
Sep 4, 2005 05:05 AM
farrski
Jun 7, 2005 09:28 AM
