Shifting issues after lowside - reluctant into first, hangs on upshifts
Old Jul 25, 2020 | 06:28 PM
RyYYZ's Avatar
Originally Posted by GBAUTO
I would complete the disassembly of the shifter pawl.
Inspect the shaft for any bending. Look closely at the attachment welds of the plate on the shaft(I've snapped those before.)
If all of that looks good, loosen the center pivot bolt and see if it wobbles as you unscrew it.
So, I found this thread here:
https://www.kawasakiforums.com/forum...r-shaft-43276/
which seems to describe my situation. I can't actually see that the mounting boss (or anything else) is bent, but something must be.
Old Jul 26, 2020 | 12:58 AM
RyYYZ's Avatar
Problem solved!
I finally decided to do something I had considered before, and shim the old, bent return spring stud so it is installed 180 degrees rotated from its original position. With that done the gap between the pawl teeth and the star nubs was about even. Bolted it back together and it shifts like a charm now.
I'm going to go back in eventually after I get some better shim washers, new neutral disk (don't ask) and retaining bolt, and a new gasket for the cover.
timc63
Jul 28, 2020 03:18 PM
Gwolf
Jun 1, 2017 02:40 AM
Matt88-8
Feb 22, 2017 04:56 PM
punkenduro09
Dec 8, 2014 08:28 AM
FiveLiterRiceEater
Sep 12, 2009 03:13 PM
