Shifter adjustment
Shifter adjustment
I have a question regarding adjusting the shifter. I want to adjust it up a notch to fit my boots so?? Do I just loosen the nut underneath or?? Sorry if it sounds dumb, just that I'm an expert at taking things apart, still working on reassembly.
RE: Shifter adjustment
To move the shifter up a notch you will need to take the bolt right out as it slots in a recess on the shaft then ease off the shifter and move it up or down 1 notch on the splines then simply put the bolt back and tighten enough so there is no slop on the shaft, and then go riding
Simon L
Simon L
Take a sharpie or something and mark the shaft and shifter so you know where you started from. Then as Simon sez (hehe) just loosen and remove the bolt...wiggle the shifter off and reinstall at your desired location. The bolt head is kinda cheesy so dont round it off.
Thanks guys, never owned anything new before and don't have a manual yet so I envisioned a spring flying out, hitting me in the eye and rolling far under my workbench (where it will be hoarded by the evil troll who collects screws, drill bits and other treasure).
ffunnyman
03-16-2007 05:02 AM
