Shift Star Fix- Detailed Write-Up?
Old May 31, 2017 | 04:46 AM
GBAUTO's Avatar
Just make sure that the collar(92152) that fits over the shift shaft is seated properly before you try to tighten down the cover-you will break the cover is you force it. There is a sticky thread that has detailed instructions on how to repair this problem
Old Jun 1, 2017 | 02:03 AM
Gwolf's Avatar
Ok folks, I followed all of information I could find, replaced the shift star, put it back together, and now the bike won't shift at all. Dowel is straight. What did I do wrong?
Old Jun 1, 2017 | 02:40 AM
GBAUTO's Avatar
You need to verify that the ratchet mechanism will rotate the shift drum. You should be able to manually rotate the drum while rocking the rear wheel- this will tell you if the problem is inside the trans or if it's in the ratchet mechanism.
bryan632
Aug 26, 2017 01:40 PM
punkenduro09
Dec 8, 2014 08:28 AM
Muttgrunt
May 25, 2009 12:36 PM
neilaction
Jul 6, 2008 03:49 AM
Kawi Wawi
Oct 8, 2006 07:03 AM
