seized
Old Jun 27, 2011 | 02:23 PM
CousinLarry's Avatar
Yah if you can't move the kickstarter - something bad happened.
You're going to need to tear it down and start investigating.
It's not a hard job, just take your time. Clean the bike well first to avoid any crap getting in the motor.
Good luck.
Old Jun 27, 2011 | 09:41 PM
wildcard's Avatar
Old trick i've used a few times is to take the spark plug out and fill the cylinder with Marvel Mystery oil (basically Auto trans fluid) or diesel and let it sit for a few days then try turing the engine over by hand. If that don't work take the head of and give the piston a few whacks with a block of wood (round and as close to the same size as the piston if possible) to free up the piston.
Otherwise it might be a fun job trying to remove the jug with the piston stuck inside...
Of course that only if it is indeed the piston that is stuck, if the crank siezed.... well ...
Old Jun 28, 2011 | 08:46 AM
dazdh's Avatar
David, yes, still has oil. TNC, it's a KLX 250 94 model.
ok fellas, thanx for the info, i'll have a go at pulling it down myself, so stand by to give me tips as i need em, i'll be relying on you guys to get me through this time of turmoil and heartache. Any advice you can give me before i start on the weekend will be greatly appreciated.
Cheers.
Old Jun 28, 2011 | 10:56 AM
David R's Avatar
Originally Posted by dazdh
David, yes, still has oil. Snip...
Cheers.
Points more toward the piston now.
David
Old Jun 28, 2011 | 07:47 PM
punkenduro09's Avatar
David
sounds like it, the only time ive seen these seize was cus of low oil, but slow speed sand riding cooking the piston would be my next guess. ive riden a lot of sand, but i also ride much hard/faster then most people with this bike so i get more air threw the radiators.
Old Jun 28, 2011 | 07:52 PM
jhoffy22's Avatar
You could have possibly folded a piston ring, but I don't know. I had the exact same thing happen this morning as you did but I have the 351 kit and everything is pretty fresh. I wasn't riding in terrible conditions like you were either.
Old Jun 28, 2011 | 11:39 PM
David R's Avatar
Two totally different situations. I would ask how do you fold a ring.
Rings break or seize. You sir broke a valve, a whole other situation for another reason.
This original poster had what I THINK is an overheating problem. I think the piston got too hot and swelled taking up too much room in the cylinder causing a bind and scoring the cylinder.
A moment of silence for dazdh and his KLX.
David
Karitane Pete
May 5, 2013 04:12 AM
mmmbeefy
Mar 25, 2013 03:21 PM
edhammac46
Jan 6, 2011 08:29 AM
kx slaughter king
Dec 7, 2008 11:30 PM
01kx125
KX125
Sep 28, 2007 03:03 AM
