seized
Old Jun 26, 2011 | 12:42 PM
dazdh's Avatar
Default seized
i was riding my in the sand dunes when i think it seized. anyone got any info what it could be, how to fix it, or wether to put a new motor in it
Old Jun 26, 2011 | 01:47 PM
CousinLarry's Avatar
Gunna need a little more info than that.
Old Jun 26, 2011 | 05:22 PM
kansas-klx's Avatar
Mine suddenly died at a stop sign yesterday while in 1st gear, clutch pulled in (out in the middle of nowhere on a 100+ degree day). Turns out the clutch cable adjustment had worked loose during the ride. Minor cardiac event at first until I realized what it was.
Hope yours turns out to be as simple.
Old Jun 27, 2011 | 03:43 AM
2007 Green Machine's Avatar
Let's all hope it did not seize. Like stated above the more experienced people ( cousin larry, tnc, dan888 just to name a few ) here will need more info. Not me of course, I'm still learning.
Old Jun 27, 2011 | 04:39 AM
Brewster's Avatar
Running the engine under a heavy load (sand) and not having much forward movement could create more heat than the radiators could dissipate causing the piston to expand and seize against the cylinder wall............I've done that with a small buggy powered by a 350 Honda street motor.
If that's the problem, you may get by with getting the cylinder cleaned up and a new piston and rings.
Ride on
Brewster
Old Jun 27, 2011 | 11:35 AM
dazdh's Avatar
well i know nothing about motors, but all i can tell you is that while i was riding it just stopped. tried to kick start it again and couldnt budge the kick. is it a big job to pull the motor down? keeping in mind i have a very limited knowledge of motors
Old Jun 27, 2011 | 01:08 PM
David R's Avatar
Could be time to go big bore. Is there any oil in the engine?
David
Old Jun 27, 2011 | 01:30 PM
jhoffy22's Avatar
It's not as hard as you think really. You just have to follow directions and heed the advice of this forum is all. Take the covers off the crank case and try to turn the engine by hand.
Old Jun 27, 2011 | 01:38 PM
Feral Donkey's Avatar
Next time ditch the regular coolant and spend the money on some Engine Ice. The top end is pretty easy to do. Get a torque wrench. Look at the top of this forum. There's a shop manual for a 2009 on a PDF file you can download. The top ends are basically the same as the earlier models.
Old Jun 27, 2011 | 02:09 PM
Ouch!...couldn't budge the kickstart? That doesn't sound like a small problem unfortunately. A kickstart...what bike do you have here?
