RockyMountainATV sends a bearing w/o protective oil, they say it's OK
Old Jan 24, 2013 | 10:47 PM
RMATV made it right.
Package arrived the other day with two, minty fresh, factory sealed parts. New bearing and water pump seal. Now that's the way to do business.
Dan
Old Jan 25, 2013 | 12:06 AM
Dan
Dan, did you check the packing material carefully for anthrax or other biological hazards? I just know this whole episode can't go this smoothly.
Old Jan 25, 2013 | 12:21 AM
Vision getting blurryy.. ... ca n't t ype.............don't f e e l s o good . ...
gassp!!! ack! ugh
Is that what you want T&C?? I keep forgetting to rub the brand spanking, almost new, shrouds I picked up, in your nose too.
Right side engine case is in the oven right now warming to 200 degrees. Bearings are in the freezer. In about ten minutes they will be dropping in.
Dan
Old Jan 25, 2013 | 02:58 AM
Lotrat's Avatar
It's been more than 10 minutes. He either burned his hand on the stove or got frost bite handleing the new bearings.
Old Jan 25, 2013 | 03:06 AM
gassp!!! ack! ugh
Dan
Shrouds?...shrouds? I don't need no stinkin' shrouds. I have an Acerbis.
Attached Thumbnails RockyMountainATV sends a bearing w/o protective oil, they say it's OK-sierra-madre.jpg
Old Jan 25, 2013 | 03:15 AM
I think it is possible to do either if you don't wear gloves while doing this.
Right side bearings went in tonight with a few taps from the bearing driver.
Left side went in last weekend. Crank/main bearing and one of the others dropped in, the other two had to be tapped in with the bearing driver. Note the frosty crank. ( The bearing driver set is a loaner from the local Autozone store, you put down the cost of the tool ,$60 in this case, and then when you return it they refund the money. It's a really nice deal)
trans back in
test fit case together.
Old Jan 25, 2013 | 03:32 AM
LikesToThump's Avatar
all that work over two bushings... wow
Looks very nice though.
Old Jan 25, 2013 | 03:45 AM
  #28
Dan, did you do any other repairs, replacements, or upgrade while you were in there? BTW, you do realize that your crank assembly will rust now due to the fridge treatment.
Old Jan 25, 2013 | 03:55 AM
  #29
Karitane Pete's Avatar
Dan
Thats what should have happened the first time, remind me why you are doing a rebuild? I have to do mine when the bits arrive
zzrick
Feb 2, 2008 03:04 AM
sinkoman
Nov 30, 2007 05:56 AM
sailfish1982
Sep 10, 2007 01:10 AM
markturbo
Oct 25, 2006 02:23 AM
espacef1fan
Sep 6, 2006 07:27 AM
